Home > Maintenance & Modifications > 90 - front springs fitted on the back
Orangesofa
United Kingdom 2013 Defender 90 Puma 2.2 SW Keswick Green
I have a 90 with what I suspect is HD springs as it had a factory tow bar which I have gleaned means the springs are probably rated as more than the standard 225lb (not sure what exactly though...). As everyone else observes, this results in a very 'crashy' ride when unladen (99.9% of the time) and I read that even the standard 225lb springs are hard enough to make the ride a bit firm to say the least.
It seams that a popular idea is to put a pair of standard front springs (175lb) on the back which has got me thinking. These are cheap as chips as they are often found as 'take off' parts from tuning houses and quite a lot cheaper than getting some custom progressive ones made by a suspension specialist.
Does anyone have first hand experience of fitting 175lb 'front' springs to the rear of a 90 and if so - what is it like?
The front springs (9446 and 9447) are different lengths, yet the standard rears are equal in length which makes me think I should match the lengths with whatever I replace them with. So - by my calculations, I would need two front passenger (9447) springs for the back to match the height of the outgoing springs or do I go for the longer driver's spring (9446) to allow for sag as they are softer? Phil
Post #492264 14th Jan 2016 4:40pm
Anderzander
I think 175's would be a bit soft ..... The later 110 fronts that are dual rate are a better option I think.
Some discussion on it here: http://www.defender2.net/forum/topic42776-15.html
Post #492287 14th Jan 2016 5:32pm
I Like Old Skool
United Kingdom 1994 Defender 110 300 Tdi ST Coniston Green
Did something like this to my 90 back in the day when Scorpion Racing were on the scene. They made me some custom +2" lift springs and I spec'd soft rears against his advice as I wanted compliant suspension off-road. I can't remember the exact numbers but I think he wanted to supply rears rated at 225lb/inch and I wanted 175lb/inch but agreed to compromise at 200lb/inch so the lift wouldn't disappear as soon as I put a shopping bag in the back.
This worked great for me and everyone always commented how the otherwise standard suspension flexed and rarely picked up a wheel when trialing and off-road. I also loved how it handled on the fast twisty roads in Wales etc and on the roundabouts of Manchester where mates could never keep up with me but did say it would pick up an inner rear wheel on the fast roundabouts Shocked
The only time the softer springs were noticeable was when travelling fastish on off-road lanes with corrugations where the rear would bottom out in each hollow, but this wasn't a show stopper as the bump stops did their job.
Post #492297 14th Jan 2016 6:03pm
TDCi Guy
United Kingdom 1996 Defender 110 300 Tdi HCPU Auto Keswick Green
Hmm I've got some front springs lying around and have been thinking about needing a less crashy ride. I might give this a go, might not get round to it for a week or two though. Tom
@tditomprice
100” Defender Hybrid
2010 Alaska White 90 HT
Post #492319 14th Jan 2016 6:50pm
Retroanaconda
I did it to mine, it made a good difference but with a bit of weight in the car or a decent-sized trailer on it kept bottoming out on bumps. Went back to standard in the end. The springs were 20+ years old though, so perhaps new ones would be better.
I suppose if you never load it up or tow anything it could be worth a try. But then one would have to ask why you have a Land Rover in the first place Smile
Post #492337 14th Jan 2016 7:40pm
Orangesofa
Depends on what you consider 'loading it up' I suppose.... If a hamper, a few bottles of fizz and a blanket counts then perhaps I do! Laughing
As for filling it with Sheep - not in a million years!
No need to tow anything as we have a horse lorry for delivering the horse places.
I bought it as it is the best 4x4 by far Wink Phil
Post #492340 14th Jan 2016 7:45pm
I Like Old Skool
2 minute job to swap rear springs Thumbs Up
Post #492349 14th Jan 2016 8:06pm
Alex1976
I did this to my Defender a couple of years ago on the advice of a guy who works at LR Gaydon ( so knows what he is talking about ) and I have never looked back.
It rides super smooth now and I don't find that I have lost any load carrying ability - well the most I load it up is about 10 bags of logs on a regular basis and this doesn't cause a problem.
I am running Terrafirma dampers - so nothing special.
I feel like I have a great suspension set up and it didn't cost anything like the figures quoted for some of the kits you can buy.
I would never go back to standard rear springs unless I needed to do some serious load carrying, and then I would look at getting progressive springs.
For the cost of some take off springs and half an hour to fit them, you haven't lost much if you decide you don't like it.
Post #492416 14th Jan 2016 10:02pm
EWS
United Kingdom 2006 Defender 90 Td5 HT Alveston Red
Hi.
Some info here
http://www.defender2.net/forum/topic40556.html
http://www.defender2.net/forum/topic32826.html
I have fitted NRC 2119 @150 to the front
NRC 4304 @170 to the rear ( Range Rover Classic springs)
Post #492440 14th Jan 2016 10:32pm
TDCi Guy
OK, had a bit of time at lunch and swapped the rear springs for some take off fronts I had (red green orange, newer models come with red green orange springs on both sides at the front), I also put on some rubber isolators top and bottom of each spring.
All I can say is WOW! The ride is completely transformed! The back end feels like a normal car. My only minor niggle is that the rear sits lower than the front even with the isolators.
I will run it with these springs for a week or two and maybe consider swapping the fronts for something a bit softer. Tom
@tditomprice
Post #492640 15th Jan 2016 3:30pm
Orangesofa
Thanks for the thoughts and opinions.
I have just ordered some standard front springs and will take the plunge. As said by others, a relatively cheap and simple mod which can be easily reversed if it doesn't work for me! Phil
Post #492642 15th Jan 2016 3:38pm
TDCi Guy
Quick photo of the difference front and rear unloaded.
 Tom
@tditomprice
Post #492646 15th Jan 2016 3:44pm
Orangesofa
Thanks Tom. Mine is a little higher on the back as I suspect I have HD springs fitted at the mo' but don't have the weight of the tow bar or the spare wheel to bring it level. This supported my thoughts that the 175lb springs would be fine as I have less rear weight without the spare. Thumbs Up Phil
Post #492647 15th Jan 2016 3:47pm
Anderzander
Tom you could probably fit a pair of those Spring isolators on the top of the back springs and gain the extra 10mm to bring the back level ?
Post #492651 15th Jan 2016 4:02pm
TDCi Guy
That's with isolators top and bottom on each spring. I might have a look at fitting the 150lb springs that EWS mentioned on the front to see if that brings things level again and takes the harshness out of the front end too. Tom
@tditomprice
Post #492666 15th Jan 2016 4:29pm
