Home > In Car Electronics > Work light wiring - need a few things confirmed
mcma1
I am adding a JW speaker work light on the rear of the rack,
http://www.jwspeaker.com/products/led-work...d/1403241/
Only 1.3amp draw.... I have a puma heated screen switch in the cubby ( with a different switch head ) that I plan to use...I know which terminals do what, currently taking illumination feed and ground from neighbouring switch... But can I just take a fused positive from the battery to switch, then switched positive out to the light without a relay?? Andy
2014 Fuji 110 SW LS3
https://www.defender2.net/forum/post751233.html#751233
2014 Corris 110 SW
http://www.defender2.net/forum/topic40056.html
My old Xtech 90 build..
http://www.defender2.net/forum/topic15681.html
LS3 V8 build...
http://www.defender2.net/forum/topic49051.html
Post #491266 11th Jan 2016 10:48pm
mark_d
2010 Defender 90 Puma 2.4 XS CSW Santorini Black
Yes. The switch should be more than capable of carrying that current.
A relay would give you the ability to add a 2nd switch at the back door if you want to turn on the light from there. http://defender90xs.blogspot.co.uk/
Post #491278 11th Jan 2016 11:15pm
Mike_B
United Kingdom 2006 Defender 110 Td5 USW Java Black
I generally fit all my accessories through relays and individual fuses. This example may not currently need its own relay, but as defender owners, the project is never finished and in five years time you might want that switch and wiring to operate something else entirely. If the wiring is up to the job and the fuse and relay are already in, it's a much easier task. I also run extra cables to future-proof my vehicle.
I'd agree that some pragmatism must be used, otherwise you'd end up with jump-lead thickness cables to power a work light, "just in case" you fancy a change.
just a thought...
Post #491286 11th Jan 2016 11:29pm
mcma1
Thanks Mark & Mike!
It's probably my last immediate wiring mod (for now)... I will get it up and running but when I have the truck stripped out for sound proofing I fully intend to refine every thing and get a nice tidy battery box like the other guys on here! Andy
2014 Corris 110 SW
LS3 V8 build...
Post #491314 12th Jan 2016 6:39am
Theater
Italy 2009 Defender 110 Puma 2.4 SW Galway Green
Land Rover FITTING INSTRUCTION :
http://topix.landrover.jlrext.com/topix/co...oupId=1662 Marco
Defender 110 "SW" SE Galway Green MY 2009
Ex Defender 90 "SW" S Santorini Black MY 2010
Post #491369 12th Jan 2016 11:10am
