Home > In Car Electronics > Work light wiring - need a few things confirmed |
mcma1 Member Since: 16 Oct 2012 Location: Northern Ireland Posts: 2925 |
I am adding a JW speaker work light on the rear of the rack,
http://www.jwspeaker.com/products/led-work...d/1403241/ Only 1.3amp draw.... I have a puma heated screen switch in the cubby ( with a different switch head ) that I plan to use...I know which terminals do what, currently taking illumination feed and ground from neighbouring switch... But can I just take a fused positive from the battery to switch, then switched positive out to the light without a relay?? Andy 2014 Fuji 110 SW LS3 https://www.defender2.net/forum/post751233.html#751233 2014 Corris 110 SW http://www.defender2.net/forum/topic40056.html My old Xtech 90 build.. http://www.defender2.net/forum/topic15681.html LS3 V8 build... http://www.defender2.net/forum/topic49051.html |
11th Jan 2016 10:48pm |
mark_d Member Since: 07 Sep 2013 Location: Northern Ireland Posts: 266 |
Yes. The switch should be more than capable of carrying that current.
A relay would give you the ability to add a 2nd switch at the back door if you want to turn on the light from there. http://defender90xs.blogspot.co.uk/ |
11th Jan 2016 11:15pm |
Thanks Mark & Mike!
It's probably my last immediate wiring mod (for now)... I will get it up and running but when I have the truck stripped out for sound proofing I fully intend to refine every thing and get a nice tidy battery box like the other guys on here! Andy 2014 Fuji 110 SW LS3 https://www.defender2.net/forum/post751233.html#751233 2014 Corris 110 SW http://www.defender2.net/forum/topic40056.html My old Xtech 90 build.. http://www.defender2.net/forum/topic15681.html LS3 V8 build... http://www.defender2.net/forum/topic49051.html |
12th Jan 2016 6:39am |
Theater Member Since: 27 Sep 2010 Location: Pisa Italy Posts: 514 |
Land Rover FITTING INSTRUCTION :
http://topix.landrover.jlrext.com/topix/co...oupId=1662 Marco Defender 110 "SW" SE Galway Green MY 2009 Ex Defender 90 "SW" S Santorini Black MY 2010 |
12th Jan 2016 11:10am |
