Home > Td5 > Daft Light Question
Tank
Scotland 2004 Defender 90 Td5 HT Zermatt Silver
Daft Light Question
OK
First things first, I am no auto electrician !
I fitted the Boomslang Performance Headlight Loom , it was easy to do, followed instructions and also decided to take power from alternator.
All has worked fine for seven months or more.
Then !
Started to get a buzz from what I thought was the switch ! Sounded like a wasp stuck in the headlight switch !
Engine off but ignition on and the following happens;
Push light switch forward one click, should be side lights ? but I get side lights and dipped. Push forward final click and lights go off and buzz starts !
Questions.
I though I wouldnt get dipped if the engine was off ? Power should be coming from alternator ?
I dont think its the switch as I replaced that tonight and still have the same problem !
Is there a relay in the lighting loom behind the steering wheel area which could be buzzing ?
Any ideas would be gratefully received !
Last thing I want is the lights to pack up one night in this Censored cold wet weather !
Tank
Post #489769 7th Jan 2016 9:40pm
Lambley
United Kingdom 2006 Defender 90 Td5 HT Java Black
I've fitted a similar loom, the lights change configuration after fitting, the headlights will be on at the first position, so there won't be a sidelight option.
I think it might be your dim-dip relay that could be suspect, an easy way to find out is unplug it. It's behind the clocks, easy to do. There's a few threads on here about it.
If you want to get the sidelight option back that's easy too.....
Post #489774 7th Jan 2016 9:56pm
mrdelmonti
United Kingdom 1999 Defender 110 Td5 CSW Portofino Red
Yep sounds like the dim-dip relay to me. Get rid of it and bypass is the proper solution, there was never any need for it to be fitted in the first place.
Post #489787 7th Jan 2016 10:18pm
Tank
Thanks for tips. Will have a go over the weekend.
Final question, should the dip beam come on if engine not on it lights wired to alternator ????
Tank
Post #489816 7th Jan 2016 11:18pm
Lambley
Not unless the ignition is on, if not on then it should just be sidelights.
Post #489817 7th Jan 2016 11:30pm
Tank
That's what I thought , will check again !
Thanks
Post #490149 9th Jan 2016 12:16am
Tank
Rather than spending £25 on a by-pass relay for the dim dip
http://www.brit-car.co.uk/product.php?xProd=138745
Can someone tell me which pins I should put the wire on to by-pass and I can make up a wire and spade terminals much cheaper !
Thanks
Tank
Post #490950 11th Jan 2016 11:37am
Martin
Site Admin
http://www.defender2.net/forum/post198252.html#198252
The bridge is shown here but I highly recommend putting spades on the ends of the wires Wink  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #490972 11th Jan 2016 1:05pm
Tank
Thanks Martin.
Coming from the boss of the forum I feel honored Bow down Bow down Bow down Bow down Bow down
Thank
Post #490976 11th Jan 2016 1:09pm
Lambley
[URL=][/URL]
The two outside middle ones
Post #490977 11th Jan 2016 1:11pm
Tank
Totally confused !
Took the tow bar electric plug apart and it was fine. No rust contacts all good. Still have the green light on the dash !
Rear lights work ok. Brake lights are really dim ??
The dim dip is knackered however when I do the wire bypass I have no lights, and I did the right bypass by the way.
Can the brake light switch at the pendal not be working right and therefore not getting the voltage to the rear brake lights ?
Aaaaaaaahhhhhh help
Anyone know a good autoeletricain in Dunfermline ?
Everything was working fine until my dim dip relay went ! Will guy another one in the mean time !
Post #492781 15th Jan 2016 9:23pm
