Home > Puma (Tdci) > Rear Panel Damage do you have the same?
Page 2 of 2 <12
Caterham
Shocked
What breather pipe!!!
I used to think I was mental to think the top half of the tank could run different to the lower half. It's got to be worth a look. Can you please advise on the breather pipe you are referring to.
Good luck with the repair. I think the mantec wheel carrier is the most popular and perhaps Brendan can help (site sponsor).
Post #489842 8th Jan 2016 8:09am
ericvv
Without any doubt, this one below here, the thinner of the two in the picture. The one that after several years starts to split at both ends and has to be replaced then, ideally preventive, you don't want to wait for a leak to develop. Caterham, suggest you start checking and changing asap.
Eric
 You never actually own a Defender. You merely look after it for the next generation.
http://youtu.be/yVRlSsJwD0o
https://youtu.be/vmPr3oTHndg
https://vimeo.com/201482507
Post #489853 8th Jan 2016 9:22am
leeds
Our red 110 has two small creases either side of the rear door.
It is a 300 TDi 1996 model. In 05 it had to be chassis due to a 'minor' incident. In 09/10 I noticed the creases, this was 40-50,000 miles after the chassis replacement which included a lot of travelling on corrugated roads.
Have not stood on spare wheel as no roof rack. Spare wheel on normal Safari Equip wheel carrier.
I was told that there are some rubber pads/spacers are between the chassis and the bodywork. That in our case the rubber pads might have 'shrunk/deteoriated' causing some movement. How true this is I do not know. Any bodywork geeks out there who can confirm/deny that?
Best wheel carrier? In my opinion the Nakatanenga stainless steel one. OK not the cheapest, however not the most expensive! It takes the weight onto the rear cross member. Of the standard swing away wheel carriers which has a top mounted drilled and bolted to the bodywork. Of the standard swing away wheel carriers I prefer the Safari Equip one. Reason being that the Safari Equip uses much longer brackets then other makes! which I think is better for weight transfer.
Ratty you are not a million miles away from us so if you want to look at some wheel carriers give me a shout.
Brendan
Post #489854 8th Jan 2016 9:22am
Pilgrimmick wrote:
the rear body used to sit inside the chassis mounting points, then it was moved,(for cosmetic reasons?) to sit outside of the chassis and led to the overhanging look that you get today. could this be a symptom of that?
Not cosmetic, it was changed for cost and tolerance reasons I believe.
With the tabs on the outside of the body panel (old arrangement) the body and the chassis have to be exactly the same length, which, with manufacturing tolerances, is quite difficult to achieve (especially with worn tooling) and hence costly.
With the later arrangement, the fixed tabs were replaced with an angle section fixed accross the rear crossmember whcih is adjustable front and rear to compensate for manufacturing variations in body length. This ia why very often the body overhangs the crossmember.
My 110 doesn't hanve the dent that the OP's has, but but ut us very apparent looking along the crossmember that the bodyline curves and the corners of the rear body are further back than the centre.
I cannot really imagine that any change to the Defender has ever been purely cosmetic - it would be a bit like slapping makeup on the ugly sister!
Post #489856 8th Jan 2016 9:29am
Caterham
[quote="ericvv"]Without any doubt, this one below here, the thinner of the two in the picture. The one that after several years starts to split at both ends and has to be replaced then, ideally preventive, you don't want to wait for a leak to develop. Caterham, suggest you start checking and changing asap.
Eric
thanks Eric.
I'll have another look. this has been changed already under warranty but I also notice the joint from plastic to rubber (on the larger one) appears to leak very slighty. must look into this and the worn fuel line - Thumbs Up
Post #489859 8th Jan 2016 9:45am
ickle
I've carried some serious weight on a roof rack with no panel deformation - but road use only.
Looks like the body is collapsing onto the chassis - what are the shut lines on the C post like (rear doors)
sales of goods act - fit for purpose? Unless you do 'Dukes of Hazard' jumps every weekend!
Post #489971 8th Jan 2016 4:55pm
milesr3
2016 Defender 90 Puma 2.2 XS CSW Keswick Green
I don't see how that can have been caused by climbing on the spare wheel. It looks more like the body has been mounted to the chassis without being shimmed correctly and it has shifted or found its position after being jolted. If it had been forced downward, then the gap between the bottom of the rear panel and crossmember would have closed up.
On my MY13 110 the rear panel is proud of the rear crossmember by 3mm with no signs of distortion. Were these last off the line Defenders assembled in a hurry?
Post #489973 8th Jan 2016 5:09pm
simond
I think this damage is due to the vehicle being driven, at some point in its life, with the rear door open. Probably due to the catch not latching, can happen with central locking.
Leverage of the door and mounted tyre in different orientation would cause deformation of bottom hinge area especially if it went over a bump. Simon D
Post #490622 10th Jan 2016 4:24pm
nickhodgson
This sort of damage is fairly common where I come from and I have seen a number of vehicles with similar creases. Old and relatively new. I usually install the rear side facing seat belt mountings as they have a support that goes from the chassis corner to the corner of the tub and I think this gives the body a bit more support. Could explain why this occurred in a utility?
This should not happen. If the panel was supposed to have a crease then it would be like that from the factory. So its a defect and should be repaired. I believe it occurs when the body moves downwards. If the body was fully supported along the chassis I would say there is no option to move downwards so you would not get a crease, so I think it is possible to get a crease if the body is not mounted correctly at the factory. Alternatively if you load that corner of the rear tub (with a spare wheel on the roof rack of a fender duel tank hanging off it or a seat for example) then its more likely. It also seems that if you drive on bad roads (as per the LR adverts so the vehicle should be suitable for it) then it occurs more often or quicker.
Nick 1995 300tdi Defender 90 P/UP
2011 Puma Defender 130 D/C
2000 300tdi Defender 110 P/UP
2015 Discovery 4 SDV6 HSE
Post #491337 12th Jan 2016 9:33am
Jonno
United Kingdom 2011 Defender 90 Puma 2.4 HT Santorini Black
Just looked at mine. No damage but on the drivers side if the body were to drop another mm it would hit the rear crosmember and bend. The rear panel is directly over the crossmember on this side.
On the passenger side the body sticks out 3-4 mm beyond the crossmember so would just miss it if it took a move downwards.
My thoughts would be it was set up like mine and has taken a battering off road the body has moved a bit and bent the alloy.
Jonno
Post #491862 13th Jan 2016 6:04pm
Jukathy
2012 Defender 110 Puma 2.2 SW Keswick Green
Rattys wrote:
I being to think its possibly from a jolt or bounce on the many off road trips we do. Which means it my catch even though I think the design should stand something like that.
The spare wheel is too heavy for the back door if your car is bouncing off road.
Just drive a little bit smoother in future or take the wheel down or have the wheel fixed on a special steel framing.
Post #492367 14th Jan 2016 9:38pm
Page 2 of 2 <12
