Home > Off Topic > Car blocking a road/removing a car blocking a road
Page 2 of 3 <123>
Grenadier
As MOG points out, looks to be part of the property. Go to the Land Registry website and it will tell you.
https://www.gov.uk/search-property-information-land-registry Monsieur Le Grenadier
2011 Puma 110DC - Corris Grey
Post #488217 3rd Jan 2016 6:23pm
mick
England 2010 Defender 130 Puma 2.4 HCPU Rimini Red
So changing the subject slightly where I keep my rib I some times struggle with double parked cars who's fault is it if my rubbing strake goes down the side as I squeeze through Whistle
Post #488228 3rd Jan 2016 6:40pm
apt100
United Kingdom 2016 Defender 90 Puma 2.2 XS CSW Aintree Green
Just a thought... if there is a vehicular ROW wouldn't that be shown on an "official" county maintained map? the map in the OP looks as though the red "shortcut" has been drawn on, which suggests the database of the original source (google maps or whoever) don't list it as a public road. Obviously there must be plenty of errors in maps but it does possibly support the theory that it is private and not part of the public highway?
Post #488230 3rd Jan 2016 6:47pm
SailingTom
Still yours unfortunately, even if illegally parked you would still have a percentage of blame.
Very rarely in the UK can you get away with shunting or ramming a vehicle!
Post #488232 3rd Jan 2016 6:52pm
Do not ever under any circumstances move someone else's vehicle unless you have their permission , even if it is totally obstructing a public highway, parked without permission on your property, blocking access to or from your property, or is or appears to be dumped (even if burned out, totalled, vandalised etc).
You do not ever have any legal authority to move someone else's vehicle without their specific permission or the authority of a Court order, and to do so, even as little as an inch, is to commit a serious offence. You might get away with it if you can prove that by doing so you've saved a life, but that is mitigating an absolute offence.
Post #488320 3rd Jan 2016 10:56pm
mse
That's not strictly true you can move anything to effect passage on a highway, as long as you only move it far enough to allow passage and you don't do any specific damage. Its usually trees or similar.
As a civilian, I would only do it in extremis though! Mike
Post #488352 4th Jan 2016 12:26am
Inanimate objects, yes. A motor vehicle, no. You are committing at least one and possibly several offences.
Obstructing a highway is, however, a serious offence, and one which is arrestable without warrant. You must however get a Policeman to deal with it.
Post #488355 4th Jan 2016 12:41am
mse
I think you will find you can move a vehicle too - i happen to have experienced it move than 10 times. Like i say, i wouldnt do it outside of work though
Oh you cant do it with people in it and there are a few other conditions Mike
Post #488358 4th Jan 2016 1:11am
I am not at present sure enough of the current situation to disute this (and of course I don't know the line of work you are in), but it certainly contradicts information I was given by the Constabulary not that long ago.
Apart from anything else, there is an obvious issue with insurance now that few standard policies include DOC cover.
Post #488426 4th Jan 2016 12:00pm
jimbob7
Sorry,but it doesn't look like a public road,in which the public have "no right of access". Pov.spec,ftw. 2006, 110,TD5.
Post #488442 4th Jan 2016 12:54pm
Mr Fox
United Kingdom 2015 Defender 90 Puma 2.2 HT Keswick Green
If it is part of the property, a conversation with the owners of the home will probably find that they are parking their vehicles there in an attempt to stop people using their property to cut the corner.
On another forum, perhaps relating to Misubishi pickups, there is quite possibly a thread running which encompasses: "How do I stop people using my property as a rat run" Wink
Post #488446 4th Jan 2016 1:07pm
scotty38
England 2012 Defender 110 Puma 2.2 USW Aintree Green
Probably agree with the above and even if it's not their property they've probably had enough of folk driving on their grass etc. I've had to put sizeable boulders on my verge to stop folk using it as a passing place when the main road is blocked and traffic uses our lane as a shortcut. A blind man on a galloping horse could see my well kept verge is part of my property but most folk see that as a green light to use it as a convenient road extension and don't give a toss about the damage they do.
Post #488449 4th Jan 2016 1:36pm
Orangesofa
United Kingdom 2013 Defender 90 Puma 2.2 SW Keswick Green
Off Topic
blackwolf wrote:
Do not ever under any circumstances move someone else's vehicle unless you have their permission even if it is... parked without permission on your property....
Errr - not true. If the vehicle is on your property the rules change significantly - hence the unregulated clamping/removals that was a huge issue a few years ago (and perhaps still is). The issue with private property and most things associated with occupation thereof or abandoning things on it is that it becomes a civil matter not a criminal one so the Five-O will wash their hands of it very swiftly
Wilful obstruction is serious (and criminal) and applies when someone intentionally blocks you in to 'prove a point' for example. Road traffic laws do still apply on private roads if they link two public roads, eg: supermarket carpark with two exits, a large public park with a road network or this very example in the OP.
So driving on such roads could see you stuck-on for not wearing a seatbelt for example.
Sorry - doesn't really answer the initial question.... Phil
Post #488457 4th Jan 2016 2:07pm
SailingTom
Like you with work we can legally shunt a parked vehicle if in the way/ parked where access is required. I think you answered it earlier though as an ordinary person wouldn't stand a chance getting away with it unless it somehow caused a life risk.
Post #488458 4th Jan 2016 2:09pm
JWL
Along with mse and Sailing Tom I agree about vehicles can be moved with minimum damage/distance etc after spending a reasonable (depends on how much of a hurry) amount of time to speak to the owner. I have moved vehicles out of farm gateways and field entrances to let us get on with our work. Yes we have made alternative arrangements to get into a field but there are times when that is the only route.
A call to the local police informing them of our intentions will often be met with their OK. It is so tempting though to leave the offending vehicle perched on the hedge or in the middle of the biggest mud hole available.
Post #488479 4th Jan 2016 3:02pm
Page 2 of 3 <123>
