- You are currently viewing DEFENDER2.NET as a guest - Register to take part or Log In
tobz102
Update from me too
Indie removed gearbox yesterday and as the clutch was taken off, the springs fell out
Having all new clutch components inc master & slave.
Whilst the gearbox is out having the output shaft between gearbox/transferbox replaced also as the splines are worn and it's causing slack.
4th May 2016 10:32pm |
