Home > Puma (Tdci) > Maintenance: Replace Brake Fluid
yaho
Poland 2007 Defender 90 Puma 2.4 SW Keswick Green
Point 21 of the Maintenance Check Sheet: Replace Brake Fluid
Does it mean I have to drain the system or top-up only? Janusz
www.yahodeville.com
Post #42916 18th Oct 2010 12:46pm
parktag
France 2008 Defender 130 Puma 2.4 HCPU Zermatt Silver
My dealer replaced the brake fluid as part of the second service. Personally i would have left it for another two years. 130 crew cab
98 V8 Disco
Post #42953 18th Oct 2010 6:04pm
merebrowpaul
United Kingdom 2009 Defender 90 Puma 2.4 HT Java Black
nothing to do with your Q i know but i was part of the truck race teams that met in Balystok before carrying on to Russia did you see any of us ? BETTER TO REGRET THE THINGS YOU'VE DONE THAN REGRET THE THINGS YOU HAVE'NT
Post #42963 18th Oct 2010 7:02pm
yaho
merebrowpaul - regret to say, but I have not seen you there. Maybe next time Smile
As for the main topic - any other inputs on brake fluid change? Mine has 40.000 km on the clock and +3 years (assuming dealers have not replaced it during theirs checks). Janusz
www.yahodeville.com
Post #43007 19th Oct 2010 6:18am
BFC Replace fluid Thumbs Up
Post #43008 19th Oct 2010 6:33am
roel
Netherlands 2003 Defender 90 Td5 PU Caledonian Blue
It should be replaced every 3 years or so. Brake fluid absorbs water and that may start boiling if you have to brake hard a few times after each other.
Was explained to me, so if I am wrong, I was told wrong. Roel
1984 90 2.5 na Diesel - RR V8 (1994-2001)
1997 Camel Trophy Discovery 300TDI (2001-2009)
2005 G4 Discovery III 4.4 V8 (2008-2018) It's gone but it still hurts.
2003 90 Td5 (2009-now)
Post #43012 19th Oct 2010 6:47am
yaho
Is replacing it a difficult thing? I can not find detailed instructions in the Workshop Manual (or am I looking at wrong page - Brake System - General Information - Brake System Bleeding; General Procedures?). Janusz
www.yahodeville.com
Post #43038 19th Oct 2010 1:05pm
Grockle
UK spec Defenders every two yrs or 24 k miles 2.4 90 XS
1968 1/32 scale Britains 109 Pick up.
Post #43041 19th Oct 2010 1:22pm
mse
Many garages can check the brake fluid to see its water content.
Some cars can go for an age, others cant...if nothing else, see if a garage has the tool to check Mike
Post #43080 19th Oct 2010 9:04pm
