Home > Puma (Tdci) > Maintenance: Replace Brake Fluid |
yaho Member Since: 26 Nov 2008 Location: Bialystok Posts: 200 |
Point 21 of the Maintenance Check Sheet: Replace Brake Fluid
Does it mean I have to drain the system or top-up only? Janusz www.yahodeville.com |
18th Oct 2010 12:46pm |
merebrowpaul Member Since: 19 Dec 2009 Location: United Kingdom Posts: 162 |
nothing to do with your Q i know but i was part of the truck race teams that met in Balystok before carrying on to Russia did you see any of us ? BETTER TO REGRET THE THINGS YOU'VE DONE THAN REGRET THE THINGS YOU HAVE'NT
18th Oct 2010 7:02pm |
merebrowpaul - regret to say, but I have not seen you there. Maybe next time
As for the main topic - any other inputs on brake fluid change? Mine has 40.000 km on the clock and +3 years (assuming dealers have not replaced it during theirs checks). Janusz www.yahodeville.com |
19th Oct 2010 6:18am |
ken Member Since: 18 Aug 2009 Location: Banging Birds with my bitches !! Posts: 4328 |
BFC Replace fluid
19th Oct 2010 6:33am |
roel Member Since: 08 Aug 2009 Location: Lelystad Posts: 2039 |
It should be replaced every 3 years or so. Brake fluid absorbs water and that may start boiling if you have to brake hard a few times after each other.
Was explained to me, so if I am wrong, I was told wrong. Roel 1984 90 2.5 na Diesel - RR V8 (1994-2001) 1997 Camel Trophy Discovery 300TDI (2001-2009) 2005 G4 Discovery III 4.4 V8 (2008-2018) It's gone but it still hurts. 2003 90 Td5 (2009-now) |
19th Oct 2010 6:47am |
Is replacing it a difficult thing? I can not find detailed instructions in the Workshop Manual (or am I looking at wrong page - Brake System - General Information - Brake System Bleeding; General Procedures?). Janusz
19th Oct 2010 1:05pm |
Grockle Member Since: 24 Nov 2008 Location: Peak District National Park Posts: 2266 |
UK spec Defenders every two yrs or 24 k miles 2.4 90 XS
19th Oct 2010 1:22pm |
mse Member Since: 06 Apr 2008 Location: UK Posts: 5035 |
Many garages can check the brake fluid to see its water content.
Some cars can go for an age, others cant...if nothing else, see if a garage has the tool to check Mike |
19th Oct 2010 9:04pm |
