Home > Puma (Tdci) > Advice please for potential Puma owner.
Steve G
Merry Christmas all,
I'm new to this forum so be please be gentle.
I am considering buying a 2007 Puma 90 HT County spec with 102k on the clock with full service history, most recent was a major service.
Bodywork is very clean but with some bubbling of paintwork around bottom corner of windscreen frame which extends slightly onto top corner of bulkhead just in front of wing mirror.
Chassis looks solid with only surface rust on rear crossmember.
£11500 is the asking price.
I will be a first time defender owner.
Thoughts very welcome.
Steve
Post #485351 25th Dec 2015 1:02pm
ickle
They're badly made, unreliable pieces of *"!? 'designed' on a fag packet whilst an Allegro was cutting edge technology.
Every journey is an adventure though, they look fine in a field or posh hotel car park, go places you probably wouldn't be able to walk and I wouldn't like to be without it.
Most things are repairable with basic kit, the windscreen frame is an alloy casting and is prone to corrosion, likewise the bulkhead, but catch them both in time & no worries.
If you can do Meccano, you can do Defender! Razz
Post #485401 25th Dec 2015 6:01pm
ickle
Post #485403 25th Dec 2015 6:05pm
fathaggis
and on top of that they command the best used car prices on the planet ............
if you have fallen for it and checked the basics . go for it Thumbs Up
Post #485404 25th Dec 2015 6:08pm
Make sure you find out when the clutch was last changed at that mileage. Otherwise if imminent it could set you back 1k.
Most people are legit but some will flog off before impeding doom. Rolling Eyes
None the less, definitely get one and you need a 90. 110's need an aircraft runway to turn around.
(Takes cover!) Whistle
Post #485410 25th Dec 2015 7:07pm
rossy
...and I found it very useful 5 years ago before I bought my 110 to read through every single page of the Puma section on Def 2 at my leisure. Takes a while but, for some reason, this site attracts intelligent, friendly, polite people who are always willing to help each other by sharing tips and knowledge. Thankfully mine has been reasonably problem free but only, I suspect, by following the maintenance advice of this great bunch of guys and gals. There's not much on telly over Christmas so start reading ! Thumbs Up
Post #485411 25th Dec 2015 7:14pm
NJS22
United Kingdom 2016 Defender 90 Puma 2.2 Adventure Corris Grey
Go for it, best thing you can do just make sure you fall in love first because then you can excuse everything like fuel economy, comfort, leaks, noise etc etc etc
I've only had about 17 Land Rover over the years Thumbs Up 1998 90 50th Anniversary 4.0 V8
2016 90 Adventure
2015 Range Rover Sport
1971 Range Rover 2 Door
Wife won't let me have any more...!!!
Post #485437 25th Dec 2015 9:51pm
Jukathy
2012 Defender 110 Puma 2.2 SW Keswick Green
12 k for a 90 from 2007 Shocked
Take a 110 for 13 k. That leaves enough space to realize almost any wild dream ...
BTW: First two Puma years are the badest Ford years.
Post #485441 25th Dec 2015 10:11pm
Hairysteve
United Kingdom 2009 Defender 110 Puma 2.4 XS CSW Barolo Black
I use these a lot when working/tinkering on my 110 Whistle http://www.ebay.co.uk/itm/100-x-Tiger-Grip...Sw6EhURAN1
Enjoy the journey Thumbs Up
Post #485443 25th Dec 2015 10:21pm
Steve G
Many thanks for the replies,
the truck is still on its original clutch, £1k for a new one, WOW.
Steve
Post #485518 26th Dec 2015 1:35pm
It is almost impossible to believe that an '07 Puma is still on its factory clutch, since most will have one or two replaced under warranty in the first three years. Very few of the early clutches were any good, and if it is the original I'll bet it rattles like a bag of nails!
If you're buying from a trader and the clutch rattles, get them to change it before the sale. If they won't, then walk away.
Post #485604 26th Dec 2015 6:29pm
^^^^ Very true, mine must have been a good one as I am on second clutch now but the first clutch went at 34k.
Other than that though mines and early Puma and so a a fair few members here and little problems.
I woundn't agree early Puma's are any more problematic than latter years, latter Puma's have their own issues too...
Vaue is about average but value, depends on condition and mileage.
High mileage usually brings it down a bit but even still they do keep value well!
Post #485610 26th Dec 2015 6:40pm
23GPS
United Kingdom 2007 Defender 110 Puma 2.4 SW Keswick Green
101k on what I believe is the original clutch on my 2007 110 , bought with 500 miles showing. Keep it simple - poverty spec.
Post #485645 26th Dec 2015 8:34pm
NJS22
2016 90 Adventure
Post #485651 26th Dec 2015 9:13pm
Amazing! My '07 is on clutch number four at 185k miles. None has worn out, always it is spring failure in the drven plate. Recent plates are better, much better, than the early ones though.
No 2 fitted c.10k miles under warranty
No 3 fitted c 58k miles
No 4 fitted c 150k miles
Always rattly springs and poor drivability.
Post #485660 26th Dec 2015 9:28pm
