Home > Puma (Tdci) > Radio code not working?
Td5
Finland 1996 Defender 90 300 Tdi CSW Coniston Green
Hello,
When I did the clutch and disconnected the battery my radio died.
The radio code has been verified from the factory by local dealer,
but it won't work? Would anybody have any ideas what to do other
than spend the holidays and trying all combinations....
The code I have is 8260.
This not much to brag about as a radio, but occasionally I would like to use it.
If somebody have one to sell, let me know. Brgds,
Juha
'96 300Tdi 90
'07 Puma 90
Post #484350 22nd Dec 2015 6:23am
kmac
I presume you follow the procedure to enter the code as specified in the manual?
I ask as I initially tired my code without referring to the manual and failed
In a Puma you have the 1 - 4 radio presents and you have to press the 1 eight times to register an 8 and the then the 2 present twice to register a 2 etc
Is this the same in yours?
If code does not work, other thing I've heard people try is putting the radio in a plastic bag in the freezer overnight but I've never tried that
Post #484677 22nd Dec 2015 10:36pm
Td5
Yes, I followed the manual and did as you describe.
I'll try the freezer trick, but somewhat doubt it as it not
uncommon here to have the whole car -20C and lower.
It can be quite cold in Finland. Brgds,
Juha
'96 300Tdi 90
'07 Puma 90
Post #484708 23rd Dec 2015 6:03am
Cake
I had the same issue - just give the dealer a call with the numbers you have a photo of and they will log it with Land Rover to get the code.
You might have to pop down there just to prove you own the car and it's not stolen or a second hand radio.
Post #484718 23rd Dec 2015 7:48am
Td5
I expressed my self poorly, the code has been verified from the factory
in UK by our official Land Rover importer. According to LR records this
is the code for this radio. Brgds,
Juha
'96 300Tdi 90
'07 Puma 90
Post #484722 23rd Dec 2015 8:06am
