![]() | Home > Puma (Tdci) > Radio code not working? |
Td5 Member Since: 29 Jun 2015 Location: Finland Posts: 53 ![]() ![]() ![]() |
Hello,
When I did the clutch and disconnected the battery my radio died. The radio code has been verified from the factory by local dealer, but it won't work? Would anybody have any ideas what to do other than spend the holidays and trying all combinations.... ![]() Click image to enlarge The code I have is 8260. This not much to brag about as a radio, but occasionally I would like to use it. If somebody have one to sell, let me know. Brgds, Juha '96 300Tdi 90 '07 Puma 90 |
Yes, I followed the manual and did as you describe.
I'll try the freezer trick, but somewhat doubt it as it not uncommon here to have the whole car -20C and lower. It can be quite cold in Finland. Brgds, Juha '96 300Tdi 90 '07 Puma 90 |
Cake Member Since: 10 Jun 2015 Location: Essex Posts: 277 ![]() ![]() |
I had the same issue - just give the dealer a call with the numbers you have a photo of and they will log it with Land Rover to get the code.
You might have to pop down there just to prove you own the car and it's not stolen or a second hand radio. |
I expressed my self poorly, the code has been verified from the factory
in UK by our official Land Rover importer. According to LR records this is the code for this radio. Brgds, Juha '96 300Tdi 90 '07 Puma 90 |
