Home > Maintenance & Modifications > Easy fit reversing camera with screen. Options please.
Stacey007
Hello
Searching for an easy fit reversing camera with screen
Lot and lots of choice especially on ebay.
I would think some people have already fitted these> Are they easy? where do you route the wires? turn it on from.
Any options / advice pass on please.
Thanks
Post #484037 20th Dec 2015 8:27pm
JAY BOY
Wales
This would not be the easiest but i would think it would be the best option.
Double din dash
Double din stereo with reversing camera input. Plus you could have TV, DVD, SAT NAV.
I think it covers all basis but probably the most expensive option. Thumbs Up
Post #484044 20th Dec 2015 8:37pm
Stacey007
^ I would like this
I cannot yet get my head round about £300 worth of plastic to cover the singe Din to double din.. and move the switches,
smartest option by far but not on the list for now....
Post #484049 20th Dec 2015 8:42pm
Try a plug in trailer cam designed for horseboxes or trailers. Ifor Williams do one, standalone so should be ready to go.
Post #484057 20th Dec 2015 8:58pm
Oakseywick
United Kingdom 2000 Defender 90 Td5 XS CSW Java Black
You could look at single din flip screen stero like below
http://www.amazon.co.uk/Single-Din-Touchsc...0ccc5cbdee
I have one of these to fit and have a bullet camera to fit in the hole in the cross member by the tow hitch, can trembler who but there is pictures on here of the camera in situ.
Post #484059 20th Dec 2015 9:08pm
JAY BOY
Wales
/\ does that have sat nav ?
Post #484067 20th Dec 2015 9:19pm
mse
Get a two camera unit with a rear mirror screen.
Simple job Mike
Post #484074 20th Dec 2015 9:47pm
JWL
After replacing yet another "cheap" radio/cd player in my Defender I thought I might trawl ebay for a secondhand "expensive" one as it may just last a bit longer. This approach has actually paid dividends and I ended up with a Sevic head unit that when new was over £400, I got it for £19.
This has got AM/FM, sd card slot, cd, dvd, iphone connection, plus with all the connectors behind it you can plug in a whole load of other things. I've plugged in my android phone with a patch lead so I can play music from the phones music player and use it as a hands free.
I went and got a cheap reversing camera off ebay for just over a fiver and plugged that in as well. Whilst it's not the same quality you'd find in your living room it's perfectly OK for me.
I put my camera up high mounted to an led work light and the cable runs along the bottom of the headlining and down the driver side A post. I think the cable that came with the camera was 4m, it did it in one with at least 18" to spare.
Post #484080 20th Dec 2015 10:02pm
Wim72
Belgium 2012 Defender 110 Puma 2.2 CSW Orkney Grey
Post #484082 20th Dec 2015 10:13pm
Oakseywick
Hi jay it does not have sat nav, but I think you can get a plug in module to add sat nav to it but not cheap.
Post #484090 20th Dec 2015 10:46pm
JAY BOY
Wales
Cheers /\
Post #484091 20th Dec 2015 11:02pm
RFT
United Kingdom 2010 Defender 130 Puma 2.4 HCPU Zermatt Silver
Try these guys in Frodsham http://vision-uk.co.uk
They have plenty of system and knowledge
I have mounted a mirror mount monitor just above the radio in front of the clock and vents
Richard 130 Puma HCPU with an Artica 240LR Demountable Camper
Post #484098 21st Dec 2015 12:31am
Garmin Nuvi Cam Thumbs Up
Post #484110 21st Dec 2015 7:04am
Mountain_man
Wales
Was thinking about this the other day. Does anyone know if such a thing as a bluetooth camera exists? That way you only need power to it and can use your mobile in a cradle as a screen. Not as neat as a permanent set up but a lot less wiring
Post #484122 21st Dec 2015 8:32am
That's how the Rear cam for the Nuvi connects Thumbs Up
Post #484145 21st Dec 2015 10:34am
