Home > Maintenance & Modifications > Easy fit reversing camera with screen. Options please. |
JAY BOY Member Since: 04 May 2010 Location: Not here Posts: 1706 |
This would not be the easiest but i would think it would be the best option.
Double din dash Double din stereo with reversing camera input. Plus you could have TV, DVD, SAT NAV. I think it covers all basis but probably the most expensive option. |
20th Dec 2015 8:37pm |
Stacey007 Member Since: 25 Sep 2015 Location: Cheshire Posts: 3745 |
^ I would like this
I cannot yet get my head round about £300 worth of plastic to cover the singe Din to double din.. and move the switches, smartest option by far but not on the list for now.... |
20th Dec 2015 8:42pm |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20308 |
Try a plug in trailer cam designed for horseboxes or trailers. Ifor Williams do one, standalone so should be ready to go.
20th Dec 2015 8:58pm |
Oakseywick Member Since: 20 Dec 2014 Location: Cirencester Posts: 1000 |
You could look at single din flip screen stero like below
http://www.amazon.co.uk/Single-Din-Touchsc...0ccc5cbdee I have one of these to fit and have a bullet camera to fit in the hole in the cross member by the tow hitch, can trembler who but there is pictures on here of the camera in situ. |
20th Dec 2015 9:08pm |
/\ does that have sat nav ?
20th Dec 2015 9:19pm |
mse Member Since: 06 Apr 2008 Location: UK Posts: 5035 |
Get a two camera unit with a rear mirror screen.
Simple job Mike |
20th Dec 2015 9:47pm |
After replacing yet another "cheap" radio/cd player in my Defender I thought I might trawl ebay for a secondhand "expensive" one as it may just last a bit longer. This approach has actually paid dividends and I ended up with a Sevic head unit that when new was over £400, I got it for £19.
Click image to enlarge This has got AM/FM, sd card slot, cd, dvd, iphone connection, plus with all the connectors behind it you can plug in a whole load of other things. I've plugged in my android phone with a patch lead so I can play music from the phones music player and use it as a hands free. I went and got a cheap reversing camera off ebay for just over a fiver and plugged that in as well. Whilst it's not the same quality you'd find in your living room it's perfectly OK for me. I put my camera up high mounted to an led work light and the cable runs along the bottom of the headlining and down the driver side A post. I think the cable that came with the camera was 4m, it did it in one with at least 18" to spare. |
20th Dec 2015 10:02pm |
Wim72 Member Since: 08 Feb 2015 Location: Kalmthout Posts: 39 |
20th Dec 2015 10:13pm |
Hi jay it does not have sat nav, but I think you can get a plug in module to add sat nav to it but not cheap.
20th Dec 2015 10:46pm |
Cheers /\
20th Dec 2015 11:02pm |
RFT Member Since: 13 Nov 2010 Location: Cheshire Posts: 678 |
Try these guys in Frodsham http://vision-uk.co.uk
They have plenty of system and knowledge I have mounted a mirror mount monitor just above the radio in front of the clock and vents Richard 130 Puma HCPU with an Artica 240LR Demountable Camper |
21st Dec 2015 12:31am |
ken Member Since: 18 Aug 2009 Location: Banging Birds with my bitches !! Posts: 4328 |
Garmin Nuvi Cam
21st Dec 2015 7:04am |
Mountain_man Member Since: 09 Dec 2011 Location: Right side of Offas Dyke Posts: 756 |
Was thinking about this the other day. Does anyone know if such a thing as a bluetooth camera exists? That way you only need power to it and can use your mobile in a cradle as a screen. Not as neat as a permanent set up but a lot less wiring
21st Dec 2015 8:32am |
That's how the Rear cam for the Nuvi connects
21st Dec 2015 10:34am |
