Home > Td5 > wont start when facing uphil
77steveb
United Kingdom 2005 Defender 90 Td5 PU Caledonian Blue
Got a 2005 defender TD5 67000 miles owned for 5 years, been fine spot on couple of months ago fuel pump started making a load of noise had this replaced, since then failed to start any time and temperatures on first key turn always started first turn before. So then had new fuel filter housing still got same problem. Then had injector harness and rocker gasket. Since then if left on a hill for more than 5 mins wont start takes a good 20 turns to start like it is full of air. When it does go it drives a few yards then judders to a stop and then takes a lot to start again but when running spot on and loads of power no bother never misses a beat no miss fire. Then had new one way value to stop diesel going back still no difference anyone got any ideas. Confused
Post #476754 27th Nov 2015 5:40pm
mk1collector
Injector seals and washers have probably gone (only fit genuine) you probably didn't need a fuel pump. Check the oil to see if it's risen at all or smells of diesel. Ray
My build thread
Post #476803 27th Nov 2015 7:33pm
airpusher
Wales 2006 Defender 110 Td5 XS DCPU Zambezi Silver
That happened to me.
On a long journey the fuel pump began to scream but drove ok.
When I got it home I reversed a it in my drive as normal and had no issues starting etc but once I spun it round and parked it front up to do some checks. It wouldn't start!
Changed the seals and copper washers, primed and it started first time.
HTH 2006 Defender Double Cab- Zambezi Silver
Post #476825 27th Nov 2015 8:24pm
77steveb
Hi mk1collector and airpusher do you know anyone around our area that could do this? thanks for the help
Post #476834 27th Nov 2015 8:53pm
77steveb
The oil hasnt risen and doesnt smell of diesel
Post #476838 27th Nov 2015 9:00pm
dorsetsmith
is the fuel pressure regulator ok, can leck. Driver side and back engine tell tall is fuel drips from start motor smell of diesel
same place
Post #476843 27th Nov 2015 9:15pm
airpusher
Hey,
My oil didn't rise but it was enough for air to get in!
I did it myself, took a couple of hours taking my time and following the instructions I found.
http://www.discovery2.co.uk/Injector%20Seals.html
I put a new harness in at the same time too.
Not an overly hard job really.
Where are you? 2006 Defender Double Cab- Zambezi Silver
Post #476853 27th Nov 2015 9:35pm
77steveb
Hi, We are in Hathersage, about 14 miles south of Sheffield
Post #476957 28th Nov 2015 10:34am
