Home > Td5 > wont start when facing uphil |
Injector seals and washers have probably gone (only fit genuine) you probably didn't need a fuel pump. Check the oil to see if it's risen at all or smells of diesel. Ray
27th Nov 2015 8:33pm |
airpusher Member Since: 04 Sep 2011 Location: South Wales Posts: 363 |
That happened to me.
On a long journey the fuel pump began to scream but drove ok. When I got it home I reversed a it in my drive as normal and had no issues starting etc but once I spun it round and parked it front up to do some checks. It wouldn't start! Changed the seals and copper washers, primed and it started first time. HTH 2006 Defender Double Cab- Zambezi Silver |
27th Nov 2015 9:24pm |
77steveb Member Since: 27 Nov 2015 Location: Hope Valley Posts: 4 |
Hi mk1collector and airpusher do you know anyone around our area that could do this? thanks for the help
27th Nov 2015 9:53pm |
The oil hasnt risen and doesnt smell of diesel
27th Nov 2015 10:00pm |
is the fuel pressure regulator ok, can leck. Driver side and back engine tell tall is fuel drips from start motor smell of diesel
same place |
27th Nov 2015 10:15pm |
Hey,
My oil didn't rise but it was enough for air to get in! I did it myself, took a couple of hours taking my time and following the instructions I found. http://www.discovery2.co.uk/Injector%20Seals.html I put a new harness in at the same time too. Not an overly hard job really. Where are you? 2006 Defender Double Cab- Zambezi Silver |
27th Nov 2015 10:35pm |
Hi, We are in Hathersage, about 14 miles south of Sheffield
28th Nov 2015 11:34am |
