Home > Technical > cam belt
NCTT
cam belt
chaps this may seem a very silly question , I have at 2010 puma , covered 16,000 miles , not much I know
however ive heard that cam belts need replacing
iss this something I should be considering soon ?
thanks sorry for my stupidity !
Post #476366 26th Nov 2015 1:54pm
Alex1976
No such thing as a stupid question! And this forum is a great place to learn lots about defenders.
As far as I know the puma engines are chain rather than belt driven and therefore do not need changing. An expert on puma engines will no doubt be along soon to confirm or deny this.
Post #476372 26th Nov 2015 2:19pm
NCTT
alex
top man , thats what i like about this forum , im not on very often but its always here with friendly advice when needed !
lets hope a puma specialist is en route !
thanks
Post #476374 26th Nov 2015 2:36pm
Triggerfinger
Deff a chain nothing to worry about for another 100,000 miles
If it starts to go it will be the tensioner but you will hear it rattling usually on starting. Wink
Here ye go.....................
http://www.landroverworkshop.com/diagrams/...hain_44993 Do it right Do it once !!!!!
Post #476392 26th Nov 2015 3:17pm
NCTT
thanks triggerfinger , top man
much appreciated , i didnt want a 500 quid bill before xmas !"!
Post #476396 26th Nov 2015 3:51pm
ian series 1
United Kingdom 2008 Defender 90 Puma 2.4 CSW Bonatti Grey
Here's one in all it's glory...
 80" 80" 86" 88" 90"
Wanted, Forward Control Anything considered.
Post #476434 26th Nov 2015 7:01pm
On the TDCi you have chain drive to the camshafts, fuel pump and oil pump (ie the critical bits), and a flat belt drive for the alternator, air con compressor (if fitted), water pump, brake vacuum pump, and PAS pump (ie the non critical bits).
I forget what the recommended intervals for replacing the belt are, but my 2007 is running the orriginal belt still at 180k miles and 8 years, and of course the original chain.
Flat belts are much longer lasting than the traditional V-belt!
Post #476444 26th Nov 2015 7:26pm
ian series 1
I had a conversation with some of the lads at our local Ford dealer, as I too needed to know what the recommended change interval was?
A few said they had never changed them, another guy said around 130,000.
I've done a few now, all around the 140,00/150,000 mark, just to be on the safe side.
Comparing old with new, there doesn't seem to be any "stretch" or wear in the chain.
The last one I did though, did have slightly worn teeth on the camshaft sprockets.
In the cam chain kit, you get new sprockets, tensioner, and crank sprocket, plus all the plastic guides, crank seal, and water way gasket.
I've always fitted a genuine seal, as the aftermarket ones seem to be a bit hit and miss in making a good seal.
Also the timing chain cover can be a bit tricky to remove without bending, so I always replace with a new one.
Cost is around £320 for the chain kit.
genuine Ford cover and seal comes in around £75.00 80" 80" 86" 88" 90"
Post #476450 26th Nov 2015 7:50pm
As far as I am aware the timing chain cover is designed as a single use item and is intended to be replaced if removed.
Post #476574 26th Nov 2015 11:25pm
X4SKP
Hello NCTT
First... thanks for asking the question... I knew some but not all of what followed...
(and you don't know what you don't know... Thud )
Second...as has been stated before... Thumbs Up to the helpful response by D2N Members. SKIP
Post #476589 26th Nov 2015 11:56pm
NCTT
cheers men , as usual a very helpful answer
i dont come on here often but when i do its always met with polite and helpful people
a credit !!
thank you
Post #476717 27th Nov 2015 4:39pm
Jonnie421
Wales 2007 Defender 90 Puma 2.4 SW Tonga Green
Yes I agree , I love this site , ask anything and you'll always get a genuine answer .
I had a query last week about an alarm topic, I had a fab answer , did what they said and now it's now perfect .
A great site the way it's run ,monitored and used Thumbs Up Thumbs Up Defender 90 Tonga green . My 2007 County .2.4Tdci puma .
Too many other Discos to mention, including a V8 petrol Disco3 and diesel Disco 3 !! ( All gone)
Post #476730 27th Nov 2015 5:35pm
