Home > In Car Electronics > advise about wiring some kit |
Cupboard Member Since: 21 Mar 2014 Location: Suffolk Posts: 2971 |
K9F:
Yes, I made the second picture as a bit of an afterthought! Have you seen this? http://www.mudstuff.co.uk/blue-sea-fuse-block.html If you're only adding a few bits and bobs. |
16th Nov 2015 1:36pm |
Thanks Mo, mild OCD affliction and being a Marine Electrical Engineer helps! Everything has to be 'just so' or I can lose sleep!
If you go through life with your head in the sand....all people will see is an ar5e!! Treat every day as if it is your last....one day you will be right!! |
16th Nov 2015 1:50pm |
jonnyboy Member Since: 15 Oct 2014 Location: Wiltshire Posts: 161 |
G-mack
Went through similar pain planning my dual battery install and, with the help of Tim at mobile solutions, came up with my design and fitted as here http://www.defender2.net/forum/topic36335.html Maybe something useful there.... John |
16th Nov 2015 5:02pm |
g-mack Member Since: 07 Jan 2014 Location: northumberland Posts: 1967 |
^^ just had a good read through that thread jonny! very nice install, It will probably help me work out my install too! My 109 thread
my youtube channel |
17th Nov 2015 9:48am |
