![]() | Home > In Car Electronics > advise about wiring some kit |
K9F:
Yes, I made the second picture as a bit of an afterthought! Have you seen this? http://www.mudstuff.co.uk/blue-sea-fuse-block.html If you're only adding a few bits and bobs. |
Thanks Mo, mild OCD affliction and being a Marine Electrical Engineer helps! Everything has to be 'just so' or I can lose sleep!
![]() ![]() Treat every day as if it is your last....one day you will be right!! |
jonnyboy Member Since: 15 Oct 2014 Location: Wiltshire Posts: 161 ![]() ![]() ![]() |
G-mack
Went through similar pain planning my dual battery install and, with the help of Tim at mobile solutions, came up with my design and fitted as here http://www.defender2.net/forum/topic36335.html Maybe something useful there.... John |
g-mack Member Since: 07 Jan 2014 Location: northumberland Posts: 1967 ![]() ![]() |
^^ just had a good read through that thread jonny! very nice install, It will probably help me work out my install too!
![]() my youtube channel |
