Home > Puma (Tdci) > 2.2 TDCi Oil Change Instructions
JOW240725
Good morning All,
I done a search for this and can't seem to find the answer, so apologies if it has been covered before.
From memory the service interval for a 2.2 TDCi is every 12,000 miles? But from reading this forum avidly it sounds like more regular oil changes are highly recommended?
Whilst I plan to have the main service carried out by a local LR specialist, I feel the interim oil change is something I ought to do myself! I just wonder if someone can point me the direction of a basic set of instructions, hopefully including a full 'shopping list' of items required?
Thank you in advance, you've not let me down before and I fully expect the answer is on here somewhere.
James
Post #471242 10th Nov 2015 9:59am
Martin
Site Admin
It is basically the same as the 2.4:
http://www.defender2.net/forum/topic8707.h...oil+change
EXCEPT
From chassis number DA444247 the filter changed to a "normal" spin-on metal canister type instead of an element in the plastic cup.
The spin-on filter is currently a Land Rover or Ford only item. LR part number LR058104, Ford 1812551 (identical filter).
AND
You must use the correct C1 spec oil: http://www.defender2.net/forum/topic34176.html?highlight=2+2+oil  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #471255 10th Nov 2015 11:05am
Vitesse
On my 2015 90xs I changed mine at around 7000 miles. I purchased a new filter and drain plug from my local LR dealer. Oil supplied by Opie specifically for the 2.2 engine. Millers C1 if I recall. I intend to change it every 6000 with the LR service on top during warranty. Maybe an overkill but I don't like 120000 intervals even though LR state it. Thumbs Up 2015 90 XS Santorini Black
Post #471292 10th Nov 2015 12:55pm
AWOL
Does anyone know if the oil service indicator is actually triggered by monitoring oil condition (or is it other usage parameters)?
I'd like to slot extra changes in but always worry that the light will be on soon after I do!
Post #472313 13th Nov 2015 7:52pm
tookaphotoof
Netherlands 2013 Defender 130 Puma 2.2 HCPU Santorini Black
Mone just goes on 20k kilometers after every reset.
Post #472335 13th Nov 2015 9:25pm
Schw8te
Germany 2013 Defender 90 Puma 2.2 SW Santorini Black
Hi
here you are: http://www.defender2.net/forum/topic25462....vice+light
Det locker bleiben
Post #472469 14th Nov 2015 3:50pm
AWOL
Thanks!
Post #472533 14th Nov 2015 8:37pm
