![]() | Home > Puma (Tdci) > 2.2 TDCi Oil Change Instructions |
JOW240725 Member Since: 04 May 2015 Location: Suffolk Posts: 7908 ![]() ![]() ![]() |
Good morning All,
I done a search for this and can't seem to find the answer, so apologies if it has been covered before. From memory the service interval for a 2.2 TDCi is every 12,000 miles? But from reading this forum avidly it sounds like more regular oil changes are highly recommended? Whilst I plan to have the main service carried out by a local LR specialist, I feel the interim oil change is something I ought to do myself! I just wonder if someone can point me the direction of a basic set of instructions, hopefully including a full 'shopping list' of items required? Thank you in advance, you've not let me down before and I fully expect the answer is on here somewhere. James |
Martin Site Admin Member Since: 02 Apr 2007 Location: Hook Norton Posts: 6638 ![]() ![]() ![]() |
It is basically the same as the 2.4:
http://www.defender2.net/forum/topic8707.h...oil+change EXCEPT From chassis number DA444247 the filter changed to a "normal" spin-on metal canister type instead of an element in the plastic cup. The spin-on filter is currently a Land Rover or Ford only item. LR part number LR058104, Ford 1812551 (identical filter). AND You must use the correct C1 spec oil: http://www.defender2.net/forum/topic34176.html?highlight=2+2+oil ![]() ![]() |
AWOL Member Since: 31 Oct 2013 Location: UK Posts: 222 ![]() |
Does anyone know if the oil service indicator is actually triggered by monitoring oil condition (or is it other usage parameters)?
I'd like to slot extra changes in but always worry that the light will be on soon after I do! |
tookaphotoof Member Since: 18 Mar 2013 Location: dordrecht Posts: 1279 ![]() ![]() ![]() |
Mone just goes on 20k kilometers after every reset.
Schw8te Member Since: 03 Jun 2012 Location: NRW Posts: 27 ![]() ![]() ![]() |
Hi here you are: http://www.defender2.net/forum/topic25462....vice+light Cheers Det locker bleiben |
Thanks!
