![]() | Home > Maintenance & Modifications > Speakers into the seat boxes? |
CFB Member Since: 13 Sep 2007 Location: Bradford, West Yorkshire Posts: 803 ![]() ![]() |
Has anyone ever fitted any speakers into the seat/battery boxes? Thinking of some 6.5" units firing into the front footwells to enhance the mid-bass (as there is none right now). There seems to be plenty of room inside both for the magnets to protrude in, can't really think of any reasons why not. Assume these are not structural so cutting holes won't affect anything?
Will still be adding the Alpine SWE-1000 sub but reckon this could be a really good sounding setup. Andy |
Lamby Member Since: 24 Mar 2008 Location: Newmarket,Cambridge Posts: 20 ![]() ![]() |
Hi mate.I put 2 6x9" in my 110 as there are 2 closed in seat boxes and it sounds really really good.The bass in very very good!.You dont even really need a amp.Wish i could do it to my 90 aswell
solmanic Member Since: 17 Aug 2007 Location: Brisbane Posts: 191 ![]() ![]() ![]() |
I agree. I would look at a compact sub-woofer to complement the smaller speakers with some high-frequency focals for high-end clarity. Have a look at this thread where there has been some discussion... http://www.defender2.net/forum/topic403.html 2007 Defender 110 1970 Alfa Romeo 1750GTV |
Seen the thread thanks, that inspired me!!
Am fitting a compact sub but was considering the 6.5" as well as they will add a bit of punch. No water gets into the seat boxes on these new ones, as someone said the fuses etc are all in the drivers side one anyhow so they would be first to go if it filled up!! Andy |
walfy Member Since: 29 Aug 2007 Location: Frome Posts: 2688 ![]() ![]() |
I've only had mine out on Salisbury Plain a couple of times, each time I go for a little play where I know there will be water. I have water splash marks over the battery and inside that side of the seatbox but so far nothing in the other side. But that doesn't mean it won't get in there 110 D250 SE HT
110 USW SOLD RRE HSE Dynamic Gone, wife killed it VOLVO XC60 R Dynamic with some toys Polaris RZR 900XP SOLD |
mse Member Since: 06 Apr 2008 Location: UK Posts: 5082 ![]() ![]() ![]() |
Well i spent 1 hour filling in the holes in the battery box on the seatbox (which is exactly the same as the TD5) So expect water in there it will happen - trust me. Mike |
If you've blocked all the holes, how's the water going to get out
Ads90 Member Since: 16 Jun 2008 Location: Cots-on-the-Wolds Posts: 813 ![]() ![]() ![]() |
I havn't looked at mine yet, so I don't know what's in there - but check that the battery has breathers to the outside (unless it's a sealed type), as you don't want the gasses to build up in there! |
Stop it getting is as it will get out the way it got in. Ive had some exposure to this - what you dont want is it in there in the first pace you can always knock a bung out to drain or rag to dry. Yes the battery is vented to the outside base Mike |
simond Member Since: 15 Feb 2008 Location: Kent Posts: 26 ![]() ![]() |
I fitted 6" drivers in the central cubby box sides next to the seat belt mountings. I created two dummy compartments for the loading of the speakers, filled with Rockwool.
I used Alpine drivers, the accompanying tweeters and crossovers were just fitted in the Puma dash. Much better sound, and if I want to turn it back to factory spec, I can just fit a new cubby box. There is a 2" cubby box now, the rest is taken up by the speaker compartment. Simon D |
