Home > Maintenance & Modifications > Speakers into the seat boxes?
CFB
Has anyone ever fitted any speakers into the seat/battery boxes? Thinking of some 6.5" units firing into the front footwells to enhance the mid-bass (as there is none right now). There seems to be plenty of room inside both for the magnets to protrude in, can't really think of any reasons why not. Assume these are not structural so cutting holes won't affect anything?
Will still be adding the Alpine SWE-1000 sub but reckon this could be a really good sounding setup. Andy
Post #2810 18th Jul 2008 4:46pm
mse
The seat box is an integral serious component. But my comment would be water - i would want stuff out of the way - not down there, but then there is a lot of other kits there.
Just one comment - the drivers side box is not as deep as the batter passenger side Mike
Post #2811 18th Jul 2008 6:13pm
Lamby
2005 Defender 90 300 Tdi HT Alveston Red
Hi mate.I put 2 6x9" in my 110 as there are 2 closed in seat boxes and it sounds really really good.The bass in very very good!.You dont even really need a amp.Wish i could do it to my 90 aswell Sad
Post #2812 18th Jul 2008 10:21pm
solmanic
Australia 2007 Defender 110 Puma 2.4 XS CSW Stornoway Grey
I agree. I would look at a compact sub-woofer to complement the smaller speakers with some high-frequency focals for high-end clarity. Have a look at this thread where there has been some discussion...
http://www.defender2.net/forum/topic403.html 2007 Defender 110
1970 Alfa Romeo 1750GTV
Post #2813 19th Jul 2008 7:50am
CFB
Seen the thread thanks, that inspired me!!
Am fitting a compact sub but was considering the 6.5" as well as they will add a bit of punch. No water gets into the seat boxes on these new ones, as someone said the fuses etc are all in the drivers side one anyhow so they would be first to go if it filled up!! Andy
Post #2814 19th Jul 2008 10:23am
walfy
I've only had mine out on Salisbury Plain a couple of times, each time I go for a little play where I know there will be water. I have water splash marks over the battery and inside that side of the seatbox but so far nothing in the other side. But that doesn't mean it won't get in there 110 D250 SE HT
110 USW SOLD
RRE HSE Dynamic Gone, wife killed it
VOLVO XC60 R Dynamic with some toys
Polaris RZR 900XP SOLD
Post #2815 19th Jul 2008 10:43am
mse
Well i spent 1 hour filling in the holes in the battery box on the seatbox (which is exactly the same as the TD5)
So expect water in there it will happen - trust me. Mike
Post #2816 19th Jul 2008 6:25pm
Laurie
If you've blocked all the holes, how's the water going to get out Rolling Eyes
Post #2818 20th Jul 2008 12:56am
Ads90
United Kingdom 2007 Defender 90 Puma 2.4 CSW Keswick Green
I havn't looked at mine yet, so I don't know what's in there - but check that the battery has breathers to the outside (unless it's a sealed type), as you don't want the gasses to build up in there!
Post #2822 20th Jul 2008 9:30am
mse
Stop it getting is as it will get out the way it got in.
Ive had some exposure to this - what you dont want is it in there in the first pace you can always knock a bung out to drain or rag to dry.
Yes the battery is vented to the outside base Mike
Post #2833 21st Jul 2008 4:00pm
simond
I fitted 6" drivers in the central cubby box sides next to the seat belt mountings. I created two dummy compartments for the loading of the speakers, filled with Rockwool.
I used Alpine drivers, the accompanying tweeters and crossovers were just fitted in the Puma dash. Much better sound, and if I want to turn it back to factory spec, I can just fit a new cubby box.
There is a 2" cubby box now, the rest is taken up by the speaker compartment. Simon D
Post #2928 26th Jul 2008 1:44pm
