Home > Puma (Tdci) > Discrepancy regarding low fuel warning in the Puma manual
Naks
Hi all,
Found a discrepancy in the workshop manual regarding the low fuel warning. Page numbers refer to the one-PDF version:
Pg 803:
A warning lamp is incorporated in the instrument cluster and illuminates when the fuel level is at or below 10 liters
(2.64 US gallons).
Pg 804:
The instrument cluster activates the yellow low fuel warning light, (next to the fuel gauge) with 15% of fuel remaining
in the tank. The fuel gauge will indicate empty with 11% of fuel left in the tank.
Now in the 90, 15% of 56L = 8.4L so which specification is the correct one!? Shocked
Post #41677 30th Sep 2010 8:01pm
fekete
Naks i have the 90 and when the light comes on i've got to get to the pump asap as its got nothing left in it ?
Maybe 4 miles NEVER TAKE LIFE SERIOUSLY. NOBODY GETS OUT ALIVE ANYWAY
Post #41680 30th Sep 2010 8:11pm
Naks
Nah, that can't be right. I have run for 50km after the light has come on. There is something wrong with your tank/fuel level sender.
Post #41681 30th Sep 2010 8:13pm
fekete
Naks i'm telling you i really need to fuel up asap when that light comes on there must be something wrong ? NEVER TAKE LIFE SERIOUSLY. NOBODY GETS OUT ALIVE ANYWAY
Post #41682 30th Sep 2010 8:16pm
Naks
Yep definitely something wrong, have it checked out
Post #41683 30th Sep 2010 8:18pm
SJM
Mine is a 90 too - I often do about another 20 miles once the light comes on before I fill up again. I'm guessing there is more left as well...?
Post #41692 30th Sep 2010 9:48pm
Eduardo
Same here at least 20-30 km with the ligth on without any trouble.ç
Cheers Eduardo
Post #41700 1st Oct 2010 12:56am
WelshGas
Wales 2010 Defender 90 Puma 2.4 XS CSW Santorini Black
I have consistently 13L left +/- 1 L when the warning light comes on in my 90 XS 2010.
Post #41703 1st Oct 2010 5:24am
CapeLandy
South Africa
on the 110 I can easily do 60km's on the light
Post #41706 1st Oct 2010 5:53am
Naks
Fekete, as an example:
Two days ago the fuel light came on, with 452km on the clock. I drove until this morning to 473km and filled her up, only 50L went in, so another 6L or so in there.
So working backwards, looks like there was approx 8L in the tank, which is closer to the 15% indicator than the 10L one.
Post #41708 1st Oct 2010 6:54am
Paul55
England 2008 Defender 90 Puma 2.4 XS CSW Santorini Black
When the fuel light comes on in my 90XS I always go for another 30mls before I fill her up. Cogito ergo sum
Post #41771 2nd Oct 2010 12:29pm
K9F
fekete wrote:
Naks i have the 90 and when the light comes on i've got to get to the pie shop asap as I've got nothing left in me? Maybe 4 miles before I get a bit grumpy!
Slight misquote perhaps? Laughing
Does anybody appreciate how hard Fekete's 90 has to work lugging all that weight around? After all he is 'The Great Northern Pie Eater Extrordinaire!'
Rolling with laughter Rolling with laughter If you go through life with your head in the sand....all people will see is an ar5e!!
Post #41772 2nd Oct 2010 12:37pm
fekete
Rolling with laughter Rolling with laughter Mal you will be burning yours off now you have got a real job Rolling with laughter NEVER TAKE LIFE SERIOUSLY. NOBODY GETS OUT ALIVE ANYWAY
Post #41774 2nd Oct 2010 1:09pm
Grockle
didn't you run out the time before Paul,after I told you so Whistle 2.4 90 XS
1968 1/32 scale Britains 109 Pick up.
Post #41778 2nd Oct 2010 1:56pm
dm_td5
Australia 2008 Defender 110 Puma 2.4 SW Zermatt Silver
Re: Discrepancy regarding low fuel warning in the Puma manua
Naks,
8.4L is 2.2 US Gal.
10L is 2.6 US Gal.
I've driven my 110 and put 70L in the tank when I refilled. I'd already added 4 x 20L jerry cans trying to get to the nearest fuel outlet and I think the Puma was running on vapour. By all accounts the vehicle should have cut out or what ever it does when it has reached the minimum fuel level.
I find the fuel light cuts in around 15% left (64L used) of the tank's supposed 75L of the 110. I wonder if they just forgot to change the calibration for the 90 Wink 110 2.4TDCi
110 300Tdi
LROCV ::: AULRO.com
Post #41799 2nd Oct 2010 8:07pm
