![]() | Home > Puma (Tdci) > Discrepancy regarding low fuel warning in the Puma manual |
Naks Member Since: 27 Jan 2009 Location: Stellenbosch, ZA Posts: 2651 ![]() ![]() ![]() |
Hi all,
Found a discrepancy in the workshop manual regarding the low fuel warning. Page numbers refer to the one-PDF version: Pg 803: A warning lamp is incorporated in the instrument cluster and illuminates when the fuel level is at or below 10 liters (2.64 US gallons). Pg 804: The instrument cluster activates the yellow low fuel warning light, (next to the fuel gauge) with 15% of fuel remaining in the tank. The fuel gauge will indicate empty with 11% of fuel left in the tank. Now in the 90, 15% of 56L = 8.4L so which specification is the correct one!? ![]() |
Nah, that can't be right. I have run for 50km after the light has come on. There is something wrong with your tank/fuel level sender. |
Naks i'm telling you i really need to fuel up asap when that light comes on there must be something wrong ? NEVER TAKE LIFE SERIOUSLY. NOBODY GETS OUT ALIVE ANYWAY
Yep definitely something wrong, have it checked out |
SJM Member Since: 09 Dec 2007 Location: Kent Posts: 237 ![]() ![]() |
Mine is a 90 too - I often do about another 20 miles once the light comes on before I fill up again. I'm guessing there is more left as well...?
Eduardo Member Since: 28 Aug 2008 Location: Región Metropolitana Posts: 2110 ![]() ![]() ![]() |
Same here at least 20-30 km with the ligth on without any trouble.ç
Cheers Eduardo MY 2007 110 SW PUMA 2.4: Big Fog of 64' MY 1994 Jayco 1207 Folding camper: "El Tremendo" ![]() Click image to enlarge |
WelshGas Member Since: 01 Oct 2010 Location: Vale of Glamorgan Posts: 935 ![]() ![]() ![]() |
I have consistently 13L left +/- 1 L when the warning light comes on in my 90 XS 2010.
CapeLandy Member Since: 21 Jul 2008 Location: Cape Town Posts: 558 ![]() ![]() |
on the 110 I can easily do 60km's on the light
Fekete, as an example:
Two days ago the fuel light came on, with 452km on the clock. I drove until this morning to 473km and filled her up, only 50L went in, so another 6L or so in there. So working backwards, looks like there was approx 8L in the tank, which is closer to the 15% indicator than the 10L one. |
Paul55 Member Since: 03 Feb 2009 Location: Somewhere in my head! Posts: 514 ![]() ![]() ![]() |
When the fuel light comes on in my 90XS I always go for another 30mls before I fill her up. Cogito ergo sum
Slight misquote perhaps? ![]() Does anybody appreciate how hard Fekete's 90 has to work lugging all that weight around? After all he is 'The Great Northern Pie Eater Extrordinaire!' ![]() ![]() Treat every day as if it is your last....one day you will be right!! |
didn't you run out the time before Paul,after I told you so ![]() 1968 1/32 scale Britains 109 Pick up. |
dm_td5 Member Since: 20 Jul 2008 Location: Arnhem Land Posts: 609 ![]() ![]() ![]() |
Naks,
8.4L is 2.2 US Gal. 10L is 2.6 US Gal. I've driven my 110 and put 70L in the tank when I refilled. I'd already added 4 x 20L jerry cans trying to get to the nearest fuel outlet and I think the Puma was running on vapour. By all accounts the vehicle should have cut out or what ever it does when it has reached the minimum fuel level. I find the fuel light cuts in around 15% left (64L used) of the tank's supposed 75L of the 110. I wonder if they just forgot to change the calibration for the 90 ![]() 110 300Tdi ![]() LROCV ::: AULRO.com |
