Home > Puma (Tdci) > Fuel cap tail mounting hole?
Td5
Finland 1996 Defender 90 300 Tdi CSW Coniston Green
Bought a new fuel cap and it has a tail.
Could someone tell me where the hole for this tail should be?
If I'm not wrong this was added in 2012?
We have so few Puma Defenders here so I can't just go and look at one.
 Brgds,
Juha
'96 300Tdi 90
'07 Puma 90
Post #467738 30th Oct 2015 6:32am
nitram17
There is a hole about 2cm away from the cap at the 1700 hours position !......you need a a drill or a pair of scissors! Laughing
Post #467747 30th Oct 2015 8:26am
Brewstop
United Kingdom 2002 Defender 110 Td5 CSW Zambezi Silver
Have a look at the MudStuff fitting instructions here:-
http://www.mudstuff.co.uk/products/exterio...l-cap.html
All it needs is a 6.5mm hole drilled into the filler recess and push the stud in to fit. Sandy
Post #467762 30th Oct 2015 10:12am
Td5
Thank you both.
I'm a bit reluctant to drill any holes in sheet metal without knowing exact location.
Clear now. Brgds,
Juha
'96 300Tdi 90
'07 Puma 90
Post #467765 30th Oct 2015 10:18am
discomog
Take a tip from me - cut the tail off the filler cap. When you undo the filler cap to fill up, it hangs down onto the bodywork and the key scratches your paintwork. I've removed the tail on mine and fitted a rubber grommet in the hole. I've also removed the cheap and nasty yellow Diesel sticker as well.
Post #467825 30th Oct 2015 1:54pm
Why leave the key in the cap it does remove. Question Idea Question
Post #467842 30th Oct 2015 2:29pm
Td5
Good points "discomog", I need to have a brew before drilling this hole.
Wondering why Land Rover did this improvement? Perhaps this effort
had been better if directed to something else. Brgds,
Juha
'96 300Tdi 90
'07 Puma 90
Post #467876 30th Oct 2015 5:07pm
jimbob7
This,also ignition key is attached to fuel key,not going anywhere without the fuel key! Pov.spec,ftw. 2006, 110,TD5.
Post #467883 30th Oct 2015 5:17pm
YOLO110
Australia
Does anyone actually lock their fuel cap? Question YOLO... You Only Live Once...
Post #467944 30th Oct 2015 9:16pm
Roy5695
United Kingdom 2011 Defender 110 Puma 2.2 XS DCPU Indus Silver
i used to lock my fuel cap, but thought if they wanted the fuel that much they would get it by just drilling a hole in the tank, id rather they just siphoned it out!
Post #470952 9th Nov 2015 2:03pm
Does the current version have any anti-syphon mechanism to stop you taking fuel out of the tank from the filler neck?
Post #470987 9th Nov 2015 4:20pm
ARC99
I lock mine so that I have to take the keys out the ignition, prevents the scum from nicking the motor. Don't make old people mad.
Richard
Post #471019 9th Nov 2015 5:41pm
Pickles
You are spot on disco.
So, when Gracie is refuelled, it takes both Wifey & I to do it. I unlock the cap, & she holds the cap until refuelling is done, after which she hands me back the cap which I replace & lock!
There's no way I want a diesel impregnated cap dangling against Gracie's paintwork!
Pickles.
Post #471118 9th Nov 2015 9:50pm
derbywill
England 2005 Defender 90 Td5 XS CSW Java Black
I don't bother locking my fuel cap, it's not like I'm carry a 1000ltrs about like a truck!
Will 2005 90 XS
1954 86'' Series 1 tilt
1968 88” 2A 200tdi
2002 110 Hardtop
Post #471120 9th Nov 2015 9:54pm
pjw4233
United Kingdom 2011 Defender 90 Puma 2.4 HT Stornoway Grey
I cut the tail off when I got a replacement and I don't bother locking the cap as the lock has a habit of freezing in winter.
Post #472007 12th Nov 2015 7:17pm
