Home > Maintenance & Modifications > Terrafirma Defender Td4 de-cat down pipe
Page 2 of 2 <12
fekete
I'm well happy with my product from Alive Tuning and the service is excellent Thumbs Up NEVER TAKE LIFE SERIOUSLY. NOBODY GETS OUT ALIVE ANYWAY
Post #41554 29th Sep 2010 3:02pm
Alive Tuning
Whether you buy your 409 grade mid pipes or decats from Bell, IRB, Allisport, or myself, they all come from the same factory, and are made to the exact same spec. It's just a matter of price, and quality of customer service. Wink
Interestingly, some peoples premium range of pipes, are our budget range! Laughing
Post #41556 29th Sep 2010 3:12pm
Sonic3d
United Kingdom 2010 Defender 110 Puma 2.4 XS DCPU Stornoway Grey
Stainless or mild steel the decat pipe is the one that lasts the longest so grade of material does not make any difference Unless you want to polish it Rolling with laughter
Post #41560 29th Sep 2010 4:41pm
Rolling with laughter Bow down
Post #41563 29th Sep 2010 5:27pm
Alive Tuning
I don't see it as an issue of how long a section of pipe lasts, but rather how well it performs. Obviously being at the hot end, it'll give many years of service no matter what grade of steel it's made from. 304 grade will scrub up nicely, but will yellow over time due to the heat.
409 grade is also more resiliant than 304 grade, to extreme temperature changes, like when being driven through deep water.
We've used 1.6mm thick 304 stainless steel on our premium decats, which is heavier than that used on the 409 pipes, and so causes less resonance in the cab, and is of course well capable of being quenched in water!
In addition to this, our 304 pipes use very high quality flexi sections, which maintain a near constant internal diameter, where as the 409 budget pipes use a (cheaper) smaller, visibly more restrictive flexi. The radius and quality of the bends are considerably better on the 304 grade systems as well. This does make a difference to performance, although it is a relatively small one.
As I said, it's a quality thing! Whether you want to polish it, is of personal preference I'm sure. Rolling with laughter
Post #41607 30th Sep 2010 12:43am
Bomber82
Italy 2009 Defender 110 Puma 2.4 SW Zermatt Silver
Got the 304 grade from Gary (Alive Tuning) and I'm very pleased with it!!
Both with standard and remap tune at low range the engine is more smooth. Thumbs Up Matteo
Defender 110 Td4 SE MY 09
Post #89051 14th Sep 2011 10:04am
lrmaniac
Portugal 2010 Defender 110 Puma 2.4 DCPU Keswick Green
Hi ... Just to my knowledge Embarassed
What are the benefits of fitting a de-cat down pipe and/or a silencer replacement pipe ?
Will it only works if the car has a remap or works fine on a standard Defender ?
Thanks! Thumbs Up Regards
Joao
'10 Land Rover Defender 110 CC
'08 BMW F800GS
'64 SIIA Forward Control
'69 SIIA 109 ZA CKD
_____________________________________________
You have the right to remain silent. Anything you say will be misquoted, then used against you.
Post #90551 22nd Sep 2011 10:33am
Naks
lrmaniac wrote:
What are the benefits of fitting a de-cat down pipe and/or a silencer replacement pipe ? Will it only works if the car has a remap or works fine on a standard Defender ?
Allows the exhaust gases to exit more quickly from the engine, allows the turbo to spool up quicker, so a bit more va-va-voom at low speeds Thumbs Up
You can do it without a remap, IMHO best bang-for-buck performance mod on any turbodiesel. --
Post #94181 14th Oct 2011 9:37am
Page 2 of 2 <12
