Home > My Defender > CDN 038's Niagara Grey 110 Td5... ongoing upgrades
Page 9 of 13 <123 ... 8910 111213>
db950
United Kingdom 1997 Defender 110 300 Tdi HT Nato Green
No problem, I'll take one later tonight!
Post #540070 14th Jun 2016 2:04pm
db950
FunkyMunky wrote:
A photo would be great! Cheers! Thumbs Up
Here you go....excuse the dirt!!
Post #540165 14th Jun 2016 7:23pm
FunkyMunky
United Kingdom 1996 Defender 110 300 Tdi CSW Alpine White
Right. Gotcha. It's a lot clearer now. Thanks for those Martin! Thumbs Up
Removed the floor earlier.... what a bitch of a job! All screws and bolts were corroded to hell so drilled and cut them out but also discovered the floor panel was just dust under some of the bolts so that needs replacing too! And at over £100 for a replacement I think i will be making my own, possibly chequer plate.
Again, cheers for the pics Martin. You da man! Thumbs Up
Post #540174 14th Jun 2016 7:38pm
db950
No problem, hope they help, but I'm not Martin!!
Post #540186 14th Jun 2016 7:50pm
Lancerdoc999
How did you seal the metal insert you made and the rivets holding the resting plate to the wheel arch? Thanks
Post #540210 14th Jun 2016 8:37pm
db950
The insert is sealed and strengthened by a product made by Wurth called Bond and Seal, extremely strong adhesive.
The rivets used are sealed rivets so don't allow water ingress.
Post #540218 14th Jun 2016 8:49pm
CDN38
Canada 2000 Defender 110 Td5 SW Bonatti Grey
Don't forget that the original floor has a stiffener channel under it. If you make your own, be sure to use a heavier gauge aluminum. and/or add a stiffener.
I Rhino lined my original floor as it was corroding around the bolts, but cleaned up ok. Reason for rhino lining was to encapsulate the aluminum. If it isn't in direct contact with any other metals, it shouldn't corrode further. (Did the front floor panels too)
 it's a Landrover thing...
my renovation thread:
http://www.defender2.net/forum/topic40792.html
Post #540222 14th Jun 2016 9:16pm
FunkyMunky
Alright, alright! Keep your hair on!
The e-mail notifications i got all have the name 'Martin' below them.......
Cheers for the pics anyway.
Post #540223 14th Jun 2016 9:23pm
FunkyMunky
Like the Rhino lining. Might see if my local coatings guys do it when i pick up the cross-member later this week.
Edit: They don't! Sad
Post #540225 14th Jun 2016 9:26pm
db950
Haha! Yes, that'll be the forum owners name:)
Post #540230 14th Jun 2016 9:41pm
FunkyMunky
Received all my panels yesterday and collected my blasted/powder-coated cross-member too so started in earnest today!
What a pain getting the old upstand off! Was double-skinned at each end and had steel domed rivets! Shocked
The old cross-member also a nightmare as nuts/boltheads were rusted and rounded off. Wouldn't have been as much of a headache but didn't want to use a grinder in there, so had to drill heads off. Rolling Eyes
On the plus side though, I did find one rusted through chassis web that needs a small repair. Not sure if it would have been an MOT fail but is an easy fix with the floor/upstand/cross-member out. Would have been a pig to do from underneath! Havent got a welding set so will take it to a mates garage on Monday.
Note to self: But some gloves to save what little knuckle skin I have left! Rolling Eyes
Post #541331 18th Jun 2016 7:02pm
FunkyMunky
Right..... seems the rear seat brackets don't fit very easily at all. As CDN 038 said, to get his brackets in he needed to lift the tub slightly. Which is impossible unless your side frames are off (mine aren't). Shocked
It also looks as though the inner bolt lugs on the rear brackets need to be right where my Boge self-levelling unit top mount sits. Rolling Eyes
Boge unit is original though and badly corroded so might remove it and uprate suspension.
Going to have to have a think about this one! Confused
Post #541539 19th Jun 2016 3:19pm
FunkyMunky
Almost there! Turned out to be a bigger job than first thought though!
 An "ex" is a has-been. A "spurt" is a drip under pressure. So an "expert" is a has-been drip under pressure.
Post #545534 3rd Jul 2016 7:23am
Justtellme
Canada 2003 Defender 110 Td5 SW Oslo Blue
How did you get the rear brackets in? Did you lift the tub and remove the side rails?
Patrick
Post #545587 3rd Jul 2016 10:14am
FunkyMunky
Hi Patrick. I had a few issues with the seat modification, perhaps because mine is a '96 CSW and the floors are slightly different on the 2010 I got the seats and brackets from? Rolling Eyes
I had a little corrosion on the top-hats and did think of replacing the floor but decided to tackle that another time as it wasn't that bad. If I had gone that route then installing the rear brackets would have been a doddle!
As the self-levelling Boge unit was in the way, I decided to remove it altogether (so far the suspension feels fine without it). Thumbs Up
Then I cut the two rear brackets in half width ways, positioned and bolted up the front halves (seats and rear locking unit in place) and welded these to the chassis box section.
I guess the chassis box section changed also over the years as there were 2 small webs either side which prevented me positioning the rear halves so off came the bolt tabs at a 45 deg angle (wish I had taken some pictures).
Then I positioned these rears, bolted them up and also welded these to the box section. Although I had removed half of the bolt tabs, there was enough to get a good weld on the inner tabs and a small weld on the outer.
Weld prep was a problem on the rear parts though as I couldn't get a grinder in, and had to use a bloody Dremmel! Rolling Eyes
A few small tacks to weld either side of each bracket halves back together and a liberal coating of waxoyl underseal, job done. Whistle
Next time I am underneath I will take some pictures, although I am not sure what will be visible under all the underseal! I did lard it on! Laughing An "ex" is a has-been. A "spurt" is a drip under pressure. So an "expert" is a has-been drip under pressure.
Post #545632 3rd Jul 2016 12:30pm
