![]() | Home > Maintenance & Modifications > Rear Lights |
No overhang ![]() Click image to enlarge You never actually own a Defender. You merely look after it for the next generation. http://youtu.be/yVRlSsJwD0o https://youtu.be/vmPr3oTHndg https://www.youtube.com/watch?v=_GtzTT9Pdl0 https://www.youtube.com/watch?v=ABqKPz28e6A https://www.youtube.com/watch?v=rLZ49Jce_n0 https://www.youtube.com/watch?v=XvAsz_ilQYU https://www.youtube.com/watch?v=K8tMHiX9lSw https://m.youtube.com/watch?v=dxwjPuHIV7I https://vimeo.com/201482507 https://www.youtube.com/watch?v=ZSixqL0iyHw |
dave18 Member Since: 11 Jul 2015 Location: Gorleston, Great Yarmouth Posts: 497 ![]() ![]() ![]() |
Where did you get the station wagon badge from I would love one but cant seem to ever find them
Fifth Horseman Member Since: 08 Mar 2011 Location: Lanarkshire Posts: 333 ![]() ![]() ![]() |
And another showing no overhang http://www.defender2.net/forum/topic9392.html - you do need to use the SVX plinth as shown by Martin for the stop/tail light though.
mse Member Since: 06 Apr 2008 Location: UK Posts: 5087 ![]() ![]() ![]() |
Do they require extra holes drilled?? Mike
Venomator Member Since: 25 Aug 2014 Location: Peterborough Posts: 2087 ![]() ![]() |
Check out http://www.artmindesign.co.uk/ and speak to Gavin, top bloke and will supply quality badges for rear and front... ![]() ![]() The GREEN One... MY2016 Urban Truck Build Thread - http://www.defender2.net/forum/topic40548....al[/color] |
Martin Site Admin Member Since: 02 Apr 2007 Location: Hook Norton Posts: 6661 ![]() ![]() ![]() |
Falon nameplates in the UK. Absolute top quality. http://www.falon-nameplates.co.uk/shop.htm You never actually own a Defender. You merely look after it for the next generation. http://youtu.be/yVRlSsJwD0o https://youtu.be/vmPr3oTHndg https://www.youtube.com/watch?v=_GtzTT9Pdl0 https://www.youtube.com/watch?v=ABqKPz28e6A https://www.youtube.com/watch?v=rLZ49Jce_n0 https://www.youtube.com/watch?v=XvAsz_ilQYU https://www.youtube.com/watch?v=K8tMHiX9lSw https://m.youtube.com/watch?v=dxwjPuHIV7I https://vimeo.com/201482507 https://www.youtube.com/watch?v=ZSixqL0iyHw |
Just to clarify, my NAS indicators use NAS plinths in which I drilled two small holes to use the original smaller lamp mounting holes. The holes I drilled are in the plinths, not the body. ![]() ![]() |
Look, no overlap
![]() This is only possible (without drilling/enlarging holes) with LED stop/tail lamps and the SVX base. ![]() Click image to enlarge ![]() Click image to enlarge ![]() ![]() |
Griff_L322 Member Since: 26 Mar 2015 Location: North Wales Posts: 89 ![]() ![]() ![]() |
You can get rdx easy plinth - no drilling
discomog Member Since: 09 May 2015 Location: Notts/Lincs Border Posts: 2537 ![]() ![]() ![]() |
I decided to combine 73mm tail/stop LED lamps with NAS Style rear indicators, reverse and rear fog LEDs, all in clear. All lamps are Wipac and I used the original reverse and fog plinths and used new plinths which utilised the original fixing holes for the indicators thus not having to drill further holes in the bodywork.
West Yorkshire Lofty Member Since: 09 Mar 2014 Location: Dumfries and Galloway Posts: 116 ![]() ![]() ![]() |
Why go NAS unless it for aesthetic's? Upgrading to standard size LED more than compensates for the size difference. WIPAC upgrade last year with no problems
![]() ![]() Click image to enlarge |
