Home > Maintenance & Modifications > Whats the best headlight bulb upgrade
Stacey007
Hello
What do people recommend as the best headlamp bulb change and what bulbs are they please.
Is this an easy swap?
Thanks
Post #461065 6th Oct 2015 8:28pm
keith
PIAA . Expensive but every time for me .
Post #461072 6th Oct 2015 8:33pm
Enid_Puceflange
Scotland 2002 Defender 110 Td5 DCPU Baltic Blue
I just purchased Osram Nightbreakers for my 90
(not yet fitted) but had read several posts on here regarding satisfying results
Ebay, £10.00 posted for a pair
G My confidence has been writing cheques that my abilities can't cash for years.
Post #461081 6th Oct 2015 8:45pm
EWS
United Kingdom 2006 Defender 90 Td5 HT Alveston Red
Go for Osram Night Breakers and Crystal headlamps, , the difference is amazing !!!!!!. More so if you do the headlight loom replacement .
Post #461086 6th Oct 2015 8:51pm
fathaggis
led headlights not bulbs Shocked
but i do use nightbreakers in my porsche
Post #461093 6th Oct 2015 9:06pm
Stacey007
LED headlights is that a complete new unit?
Are the bulbs in a Defender H7's
Thanks
Post #461095 6th Oct 2015 9:09pm
Enid_Puceflange
I bought H4 for mine Thumbs Up
Post #461110 6th Oct 2015 9:30pm
shaggydog
I did a write up for the conversion from standard to Wipac Cyrstals and Osram Nightbreakers here http://www.defender2.net/forum/topic24287.html?highlight=wipac
Coupled with a Red Bison Loom its the best upgrade you can do for your truck without spending a fortune on LED lights.
Think my whole conversion cost less than £60 including the loom, lights, bulbs and a packet of biscuits. Running Restoration Thread http://www.defender2.net/forum/post323197.html#323197
Post #461136 6th Oct 2015 10:30pm
BuckBlu110
United Kingdom 1994 Defender 110 BMW M57 3.0 Diesel CSW Buckingham Blue
Defenders are wired for h4 bulbs, and as above, osram night breakers and wipac crystal headlights are a huge improvement over standard, if you want to go further take a look at upgrading the wiring loom, again another big step up, but if you want proper brightness, and aren't worried about spending a few hundred on lights, go led.
The difference between standard and led, is literally like night and day!
Post #461137 6th Oct 2015 10:32pm
Philips Extreme here. Thumbs Up
Post #461154 6th Oct 2015 11:17pm
stooby do
As recommended a lot on here I recently went with the Wipac Crystal lamps, Osram Nightbreaker bulbs and the Red Bison boomslang loom, unbelievable improvement for the money.
Post #461819 9th Oct 2015 1:59pm
Landy-Novice
fitted on mine, crystal lights with 90/130w bulbs with boomslang loom and a 52" led light bar for good measure! Whistle Thumbs Up Thumbs Up
Post #462107 10th Oct 2015 6:37pm
Stacey007
Hello
Has anyone a link for the uprated loom and clear lens, Is the loom a big job?
sounds like it could be?
Think for now it will be Osram nightbreakers unlimited, purely as I have a pair I never fitted to my wifes car and then we sold it...
Post #462113 10th Oct 2015 6:59pm
Landy-Novice
loom is almost plug and play, i extended my main pos and neg so both reach alternator.
loom: http://www.paddockspares.com/boomslang-per...-loom.html
or here, exact same, alot cheaper(one i use) http://www.ebay.co.uk/itm/111466280732
clear headlights: http://www.ebay.co.uk/itm/RTC4615C-7-LAND-...4d2fc73f49
or if your a tart like me. clear halos. http://www.ebay.co.uk/itm/Angel-Eye-Headli...5d3ca16796
Thumbs Up
Post #462114 10th Oct 2015 7:06pm
Just bear in mind. When swapping headlights that they'll likely need re-alignment especially for the MOT.
So I'd recommend taking if to one and asking for them to be aligned, it'd cost peanuts too.
I only found this out come MOT time myself, luckily the tester just adjusted them and passed still FOC.
Post #462118 10th Oct 2015 7:17pm
