Home > My Defender > My first defender!
Page 2 of 2 <12
K9F
hugh_b wrote:
Now has safari snorkel and new side steps!
Much better than the woodburner flue you had fitted previously! Laughing If you go through life with your head in the sand....all people will see is an ar5e!!
Post #42777 17th Oct 2010 7:58am
hugh_b
Laughing
I know! looks far smarter! Really pleased with it now. Would like some at tyres but not a necessity as the grabbers are almost new!
Post #42967 18th Oct 2010 7:30pm
MrFlips
Wales 2008 Defender 90 Puma 2.4 PU Santorini Black
Be warned Hugh - the Grabbers will last forever and drive you insane as you wait for them to wear down just a little to justify removing them and fitting your tyres of choice. (I lasted nine months before selling mine). Peter
2008 SWB Truck Cab
1952 80" Soft top
Post #42991 18th Oct 2010 9:10pm
alanhid
Scotland 2006 Defender 90 Td5 XS CSW Bonatti Grey
Looking good...Im going to order a safari snorkel next week, how did you find fitting it? Any tips or hints. There is a good clip on ebay which shows fitting a safari to a TD5 and it looks relatively straightforward. Life is not a rehearsal!
Def 90td5 CSW xs 2006
Post #43037 19th Oct 2010 12:55pm
hugh_b
Yeah i watched the vid a couple of times. Was pretty easy really, the hardest part is getting the pipe work on but even that wasn't too bad with some fairy liquid as suggested in the video.
Mine went on pretty well, you have to make sure the windscreen pillar bracket will line up nicely with the actual pillar before you drill the holes in the wing. I assume thats why they tell you to drill 16mm holes...to give you some margin for error.
I ended up drilling 13mm holes...i did try 10mm but it wasn't quite right and the next drill bit up i had was a 13mm Laughing
Hugh
Post #43055 19th Oct 2010 5:36pm
hugh_b
Laughing I will no doubt give up at some point but for now i can't justify it...bfg's are not cheap!
They would finish it off nicely though Rolling Eyes Laughing
Post #43056 19th Oct 2010 5:38pm
alanhid
Hugh,
ive got my safari, it came today. Instructions say that you have to remove the radio ariel......did you? Life is not a rehearsal!
Post #43789 28th Oct 2010 2:09pm
hugh_b
alanhid wrote:
Hugh,
No, you don't need to remove the ariel, read that elsewhere also.
Hugh
Post #43968 30th Oct 2010 5:42pm
alanhid
Cheers mate.............but I ended up having to remove it for easier fitting, but got it back on though. Thats it fitted...well chuffed. Life is not a rehearsal!
Post #43969 30th Oct 2010 5:57pm
Page 2 of 2 <12
