Home > My Defender > My first defender! |
Much better than the woodburner flue you had fitted previously! If you go through life with your head in the sand....all people will see is an ar5e!! Treat every day as if it is your last....one day you will be right!! |
17th Oct 2010 7:58am |
MrFlips Member Since: 27 May 2009 Location: Cardiff Posts: 682 |
Be warned Hugh - the Grabbers will last forever and drive you insane as you wait for them to wear down just a little to justify removing them and fitting your tyres of choice. (I lasted nine months before selling mine). Peter
2008 SWB Truck Cab 1952 80" Soft top |
18th Oct 2010 9:10pm |
alanhid Member Since: 24 Jan 2010 Location: South Lanarkshire Scotland Posts: 221 |
Looking good...Im going to order a safari snorkel next week, how did you find fitting it? Any tips or hints. There is a good clip on ebay which shows fitting a safari to a TD5 and it looks relatively straightforward. Life is not a rehearsal!
Def 90td5 CSW xs 2006 |
19th Oct 2010 12:55pm |
hugh_b Member Since: 15 Sep 2010 Location: Kent Posts: 75 |
Yeah i watched the vid a couple of times. Was pretty easy really, the hardest part is getting the pipe work on but even that wasn't too bad with some fairy liquid as suggested in the video. Mine went on pretty well, you have to make sure the windscreen pillar bracket will line up nicely with the actual pillar before you drill the holes in the wing. I assume thats why they tell you to drill 16mm holes...to give you some margin for error. I ended up drilling 13mm holes...i did try 10mm but it wasn't quite right and the next drill bit up i had was a 13mm Hugh |
19th Oct 2010 5:36pm |
I will no doubt give up at some point but for now i can't justify it...bfg's are not cheap! They would finish it off nicely though |
19th Oct 2010 5:38pm |
Hugh,
ive got my safari, it came today. Instructions say that you have to remove the radio ariel......did you? Life is not a rehearsal! Def 90td5 CSW xs 2006 |
28th Oct 2010 2:09pm |
No, you don't need to remove the ariel, read that elsewhere also. Hugh |
30th Oct 2010 5:42pm |
Cheers mate.............but I ended up having to remove it for easier fitting, but got it back on though. Thats it fitted...well chuffed. Life is not a rehearsal!
30th Oct 2010 5:57pm |
