Home > Technical > 110 CSW now without self levelling and Winch bumper, which
dave18
United Kingdom 1984 Defender 110 300 Tdi CSW Portofino Red
Hey peeps, my 110 CSW originally had self levelling but the PO removed it but I don't think they changed the springs. I'm sure I read on here that if you remove the self levelling unit then it's best to fit Td5 progressive rear springs. Is this correct and if so are they skidded or do they fit on both sides ??
Also going to fit a winch, winch bumper, A bar and sump guard thus thinking best to go HD front springs. Been told LR do HD fronts is this correct???
Guessing I can run stock dampers with no issues?
Ideally want to fit LR components where possible for ease.
Post #458897 29th Sep 2015 8:06am
Dpgdefenders
Replace the rear springs and shocks with standard 110 items, rtc4639 shocks, nrc6389 drivers side spring and nrc6904 passenger side spring, or for a good budget kit, try the terrafirma tf199 heavy duty kit, standard vehicle height. The terrafirma kit is as easy to fit as the LR stuff.
Post #459082 29th Sep 2015 7:23pm
dave18
Cheers for the reply thought I said cheers the other day but obviously didnt.
What about the front is there a HD LR set ??
Post #460051 3rd Oct 2015 10:17am
Retroanaconda
I believe 110 front HD springs are the same as 90 standard rears.
Post #460053 3rd Oct 2015 10:26am
dave18
Retroanaconda,
Cheers been doing some googling and your right HD90 Rears are the same as HD 110 fronts Smile. So just got to decide should I go for the Britpart ones or go to LR, Im guessing since they are LR spec and colour coded then its proberbly the same factory unlike their +2" springs!!
Does anyone think I will need uprated from Dampers or is stock ok ?? Im not 100% sure.
Post #460056 3rd Oct 2015 10:46am
mikeh501
Give gwyn Lewis a bell before you decide
Post #460063 3rd Oct 2015 11:41am
dave18
Would like a wallet left!!! Will have a look but can't see the need for uprated suspension bar what I've asked. But will look
Post #460076 3rd Oct 2015 12:05pm
Retroanaconda
Genuine springs and dampers all the way.
Post #460187 3rd Oct 2015 9:04pm
mikeh501
I just meant that he will be able to provide good advice on spring rates. The ome springs won't break the bank and you can get some springs which are tailored for the weight and usage of the vehicle.
Post #460190 3rd Oct 2015 9:21pm
dave18
Mike, Cheers thought you meant get one of his challenge kits or something !!!
Post #460200 4th Oct 2015 4:14am
