![]() | Home > Technical > 110 CSW now without self levelling and Winch bumper, which |
Dpgdefenders Member Since: 11 Nov 2014 Location: North Yorkshire Posts: 9 ![]() |
Replace the rear springs and shocks with standard 110 items, rtc4639 shocks, nrc6389 drivers side spring and nrc6904 passenger side spring, or for a good budget kit, try the terrafirma tf199 heavy duty kit, standard vehicle height. The terrafirma kit is as easy to fit as the LR stuff.
dave18 Member Since: 11 Jul 2015 Location: Gorleston, Great Yarmouth Posts: 497 ![]() ![]() ![]() |
Cheers for the reply thought I said cheers the other day but obviously didnt.
What about the front is there a HD LR set ?? |
Retroanaconda Member Since: 04 Jan 2012 Location: Scotland Posts: 2693 ![]() ![]() |
I believe 110 front HD springs are the same as 90 standard rears.
Retroanaconda,
Cheers been doing some googling and your right HD90 Rears are the same as HD 110 fronts ![]() Does anyone think I will need uprated from Dampers or is stock ok ?? Im not 100% sure. |
mikeh501 Member Since: 07 Jan 2013 Location: United Kingdom Posts: 1142 ![]() ![]() |
Give gwyn Lewis a bell before you decide
Would like a wallet left!!! Will have a look but can't see the need for uprated suspension bar what I've asked. But will look
Genuine springs and dampers all the way.
I just meant that he will be able to provide good advice on spring rates. The ome springs won't break the bank and you can get some springs which are tailored for the weight and usage of the vehicle. |
Mike, Cheers thought you meant get one of his challenge kits or something !!!
