Home > Maintenance & Modifications > Rear upper shelf, Glove box and raising cubby box
TACK
Thougt I would post these pictures of the shelf I installed in the back of my USW, gives a few ideas for pep's on storage space.
We went away recently and managed to storage up there a G4 Kyham tent, 2 sleeping bags in compression sack, 3 pillows, an empty day sack and my camera case for my SLR, so it looks small but it does a really good job for normally wasted space Thumbs Up
Post #40510 14th Sep 2010 9:31pm
double cab happy
England 2007 Defender 110 Puma 2.4 DCPU Java Black
did the same myself, defo a good idea.
Post #40513 14th Sep 2010 10:25pm
ti-fat-man
United Kingdom 2011 Defender 110 Puma 2.4 USW Alpine White
right it's offically not fair...
how come you guys are good at this metalwork fabrication stuff.
tack...what/how did you make that shelf and what supports has it?
just the ticket that... Thumbs Up
Post #40514 14th Sep 2010 10:42pm
TACK
Ali Angle iron, ali 2mm sheet, riveted togther then line the existing bolts which hold the top part of the cab to the middle part for you holes, mark, drill through the angle iron. Bolt up. I made spacers to so the shelf can be lowerd too if I want Thumbs Up
Do you want me to make you one?
Post #40517 14th Sep 2010 11:03pm
discocuzzy
Yes please Tony Very Happy Very Happy Very Happy You cannot teach stupid people to do clever things
Post #40522 15th Sep 2010 12:26am
ti-fat-man
tack...
yes is the answer... Thumbs Up
i'll pm you, take it the side trims got to go though.
i did look at the jobbie from boab, was an open affair with wooden slats (ikea like) £100 plus... Shocked
Post #40523 15th Sep 2010 12:53am
jst
i used a mates spare car dog guard on its side so it sits horizontally. Cheers
James
110 2010 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #40535 15th Sep 2010 9:28am
TACK
Al the internal side panels would have to come off for the same shelf to fit as no other way to get to the fixings. I would use mine as the template (means you will get the better one) but in my short ownership of a def2 I have realised not every one of them is the same and thus I would need to check the dims of the spacing between the top bolts Thumbs Up
Does the ladder for your roof tent get stored in the def2 as I could make the brakets like mine to house the ladder under the shelf out of the way, works well as the ladder it tends to be the first thing out and last thing to put away. If you see in my pic's there is foam strips stuck to the underside of the shelf, this stops the ladder from rattling against the shelf if there is movement Question Thumbs Up
Steve no probs, beer tokens openly received Mr. Green
Post #40585 15th Sep 2010 10:27pm
TACK
Again, just for ideas, made a glove box on the passenger side a few months ago and just got round to taling some pics would apear Entreq copied me Laughing
I rasied the hight of my cubby box again months ago, but i then raised the seat with mud rails, so i was back to square one again with the height, could not find a leather pad on the market to use so..... went up some more, used the same plastic as i did for the glove box to tidy it up at bit Very Happy
Post #40755 17th Sep 2010 6:47pm
fekete
Tony your a genius Bow down Bow down NEVER TAKE LIFE SERIOUSLY. NOBODY GETS OUT ALIVE ANYWAY
Post #40757 17th Sep 2010 7:17pm
dgardel
Italy
I have this one........
 Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
IID Pro MV License
Post #40783 18th Sep 2010 12:34am
TACK
two minds think a like Thumbs Up
Post #40791 18th Sep 2010 9:19am
mse
I thought of that when i took it off for something.
The SVX has a neat pouch under there that got me thinking.
What did it take to do? Mike
Post #40793 18th Sep 2010 9:23am
dm_td5
Australia 2008 Defender 110 Puma 2.4 SW Zermatt Silver
dgardel does the glove box just bolt in after you remove the foam liner under the top panel or do you reuse the top panel and screw in the hinges?
I think I'm making sense Confused 110 2.4TDCi
110 300Tdi
LROCV ::: AULRO.com
Post #40795 18th Sep 2010 10:08am
dgardel
Italy
you must remove the polystyrene foam, cut the long plastic hump and screw the top panel on the new hinges plate. Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
IID Pro MV License
Post #40812 18th Sep 2010 2:48pm
