Home > Tdi > 300 Tdi Throttle Cable
Tim W
United Kingdom 1995 Defender 90 300 Tdi HT Alpine White
Evening all,
Just a quick one. Changing the throttle cable on my Tdi as it's a bit goosed. The part is NTC9360 and I've ordered a non-genuine replacement for a tenner. I've noticed the genuine ones are around £50/60+.
Anyone with experience know if the genuine ones are massively better or are you just paying for an OEM stamp?
Cheers in advance!
Post #458483 27th Sep 2015 6:21pm
grumpy old git
OEM for under a tenner Thumbs Up
NTC9360 - THROTTLE CABLE 300TDI RHD DEFENDER
I used a Eurospare bonnet release on my D2, virtually identical to the one I removed and no problems. The only thing I did before fitting it was hang it up in the workshop and run some mountainbike lube down the liner for a couple of days.
Post #458547 27th Sep 2015 9:01pm
Tim W
Cheers for that!
I've actually already ordered a sub £10 cable. But in that link you can see the "genuine" ones are £58+VAT! I just can't figure out why!
I'm also in two minds about lube between the cable and the outer.. Yep 100% will run more freely, but also more chance of attracting crud.. Just my experience with bikes!
Anyway cheers again for the response!
Post #458557 27th Sep 2015 9:48pm
