Home > Tdi > 300 Tdi Throttle Cable |
grumpy old git Member Since: 16 Nov 2013 Location: United Kingdom Posts: 153 |
OEM for under a tenner
NTC9360 - THROTTLE CABLE 300TDI RHD DEFENDER I used a Eurospare bonnet release on my D2, virtually identical to the one I removed and no problems. The only thing I did before fitting it was hang it up in the workshop and run some mountainbike lube down the liner for a couple of days. |
27th Sep 2015 9:01pm |
Tim W Member Since: 01 Apr 2014 Location: North West Posts: 13 |
Cheers for that!
I've actually already ordered a sub £10 cable. But in that link you can see the "genuine" ones are £58+VAT! I just can't figure out why! I'm also in two minds about lube between the cable and the outer.. Yep 100% will run more freely, but also more chance of attracting crud.. Just my experience with bikes! Anyway cheers again for the response! |
27th Sep 2015 9:48pm |
