Home > Td5 > Need help...
Page 2 of 2 <12
K9F
Definitely needs cleaning out thoroughly. A decent electrical contact cleaner or isopropyl alcohol and a soft brush. I would decontaminate and clean the oil away thoroughly before pursuing other avenues.
If you have a Maplins near you or perhaps any decent pharmacist for the alcohol or Halfords for some cleaner. .
http://www.maplin.co.uk/p/isopropyl-alcohol-400ml-re79l
http://reviews.halfords.com/4028/778340/reviews.htm If you go through life with your head in the sand....all people will see is an ar5e!!
Post #462019 10th Oct 2015 9:18am
Derrickthedefender
United Kingdom 2004 Defender 90 Td5 SW Zambezi Silver
So I have cleaned off the connectors and reconnected, now when trying to start it barely turns over, is I possible I have tried to turn it over too much? A Defender... Mans best friend, never judges, trustworthy (most of the time), go anywhere, do anything, looks the business, and mans biggest money pit!!!
Yes the name for my 90 is Derrick!
Post #462048 10th Oct 2015 12:48pm
K9F
Probably. Any means by which you can either charge or measure the battery terminal voltage? If you go through life with your head in the sand....all people will see is an ar5e!!
Post #462070 10th Oct 2015 2:41pm
Derrickthedefender
Okay, recharged and tried again, started first time, ran it for a while and went for a little drive, no dramas so far.... Thank you to all that helped, yet another reason why def2.net is invaluable to those who used it..
Thanks again A Defender... Mans best friend, never judges, trustworthy (most of the time), go anywhere, do anything, looks the business, and mans biggest money pit!!!
Post #462167 10th Oct 2015 8:41pm
K9F
Great news. Hopefully 'done and dusted' or perhaps a little more apt 'lubed and cleaned.' Whistle Thumbs Up If you go through life with your head in the sand....all people will see is an ar5e!!
Post #462195 10th Oct 2015 11:10pm
mk1collector
Thumbs Up excellent news Ray
My build thread
Post #462196 10th Oct 2015 11:17pm
Page 2 of 2 <12
