Home > Td5 > Need help... |
Definitely needs cleaning out thoroughly. A decent electrical contact cleaner or isopropyl alcohol and a soft brush. I would decontaminate and clean the oil away thoroughly before pursuing other avenues.
If you have a Maplins near you or perhaps any decent pharmacist for the alcohol or Halfords for some cleaner. . http://www.maplin.co.uk/p/isopropyl-alcohol-400ml-re79l http://reviews.halfords.com/4028/778340/reviews.htm If you go through life with your head in the sand....all people will see is an ar5e!! Treat every day as if it is your last....one day you will be right!! |
10th Oct 2015 9:18am |
Probably. Any means by which you can either charge or measure the battery terminal voltage? If you go through life with your head in the sand....all people will see is an ar5e!!
10th Oct 2015 2:41pm |
Derrickthedefender Member Since: 28 Jan 2014 Location: South Posts: 294 |
Okay, recharged and tried again, started first time, ran it for a while and went for a little drive, no dramas so far.... Thank you to all that helped, yet another reason why def2.net is invaluable to those who used it..
Thanks again A Defender... Mans best friend, never judges, trustworthy (most of the time), go anywhere, do anything, looks the business, and mans biggest money pit!!! Yes the name for my 90 is Derrick! |
10th Oct 2015 8:41pm |
Great news. Hopefully 'done and dusted' or perhaps a little more apt 'lubed and cleaned.' If you go through life with your head in the sand....all people will see is an ar5e!!
10th Oct 2015 11:10pm |
excellent news Ray
10th Oct 2015 11:17pm |
