Home > Maintenance & Modifications > Rear shock washers/bushes
Page 2 of 2 <12
Thumbs Up
Post #457840 24th Sep 2015 7:17pm
Screbble
As I firmly tighten the lid firmly on that can of worms Laughing
I can confirm that the deed is done, and the washer/bush configuration on the in-situ 'originals' was entirely consistent with that agreed on this thread Thumbs Up
As Ann aide memoire:
For info, the job itself took no more than an hour to complete both sides with adequate tea breaks Rolling Eyes
Let's face it, it's only two nuts, but the bush/washer configuration is important. I did spend a bit of time cleaning the axle cups given the reported issues relating to the bushes. It's surprising how much crud was in present.
I can feel the lid coming off that can....
I went for the 10mm of thread principle rather than torque setting for the bottom nut....
Thanks all Bow down
Post #458350 27th Sep 2015 9:34am
Looks right to me. Thumbs Up
Don't forget to Dinitrol the nuts and washers etc once fitted.
Yes, the rears are easy...
The fronts not quite so much. Laughing
Post #458361 27th Sep 2015 10:53am
landybear
United Kingdom 2003 Defender 90 Td5 HT Belize Green
I've just bough some Terrafirma shocks for the rear of my 2003 90 and they come with a supplement to say that on post 1994 vehicles the lower cups (fixed on the axle) should be removed. Is this normal as its doesn't feel right? 2003 Defender TD5 Hardtop (current - work in progress)
2014 Discovery 4 HSE (Current) / 2009 Discovery 3 HSE 2009 (Previous)
Disco 2 Landmark 2004, 2001, 2002 (Previous)
Disco 1 300tdi 1996 & V8i 1995, 200tdi 1993 (previous)
Defender 110 300tdi 1993 (Previous)
Range Rover Vogue 4.6 - 2001 (Previous)
Freelanders TD4 (2001 3 door & 2002 5 door) Previous
90 2.5 then converted to V8i (1990), 90 2.25 then converted to v8 (1986) plus others
Post #483722 19th Dec 2015 4:09pm
Retroanaconda
To save designing two types of shock absorbers to suit early and late vehicles some aftermarket manufacturers suggest removing the fixed cups. This, combined with the bushes/washers included with the new shocks, effectively converts the vehicle to the earlier type.
Later shocks have longer pins because the bushes are deeper.
Post #483756 19th Dec 2015 6:49pm
Dave T
United Kingdom 1994 Defender 90 300 Tdi SW Cairns Blue
Just dragging this up again, my rear shocks are fine, its just the washers that are no use, does anyone know where I can get rear shock lower washers, as per the old set up, I have had the axle brackets replaced so no longer have captive cups. I just cant see them anywhere 2015 RRS Autobiography SDV6
1994 Def 90 300tdi
Post #627949 31st May 2017 11:43am
Page 2 of 2 <12
