Home > Technical > Unusual hub seal
Peter
United Kingdom 2005 Defender 90 Td5 SW Epsom Green
Unusual hub seal
About 10 years ago the back axle on my Ninety was changed to disc break. I had to change a hub seal yesterday.
I found it had an inner and outer hub seal. On all the kits they have just one seal. Does anyone know what this axle may have come from and where I get the outer seal from. It's different from the standard inner seal.
Thanks
Peter
Post #455634 16th Sep 2015 7:08pm
Triggerfinger
A picture would be helpful matey, is a metal ring with a rubber seal attached ??
Cheers Kev
Post #455666 16th Sep 2015 8:55pm
I Like Old Skool
United Kingdom 1994 Defender 110 300 Tdi ST Coniston Green
The original drum braked axle on my old 200tdi 90 had inner and outer hub seals as you describe. I wonder if the 200tdi Discovery axles from the time (these had discs) used the same hub set-up and this is what you have? 10 years ago there would have been loads of 200tdi discovery axles available while the genuine 300tdi Defender axle was a much rarer beast.
Post #455756 17th Sep 2015 10:17am
