![]() | Home > Technical > Unusual hub seal |
Triggerfinger Member Since: 18 Aug 2015 Location: landyrotty Posts: 129 ![]() ![]() |
A picture would be helpful matey, is a metal ring with a rubber seal attached ??
Cheers Kev |
I Like Old Skool Member Since: 23 Feb 2015 Location: Manchester Posts: 829 ![]() ![]() ![]() |
The original drum braked axle on my old 200tdi 90 had inner and outer hub seals as you describe. I wonder if the 200tdi Discovery axles from the time (these had discs) used the same hub set-up and this is what you have? 10 years ago there would have been loads of 200tdi discovery axles available while the genuine 300tdi Defender axle was a much rarer beast.
