![]() | Home > Technical > 1985 Ninety, leak at rear wheel |
Tfaerch Member Since: 16 Aug 2015 Location: Copenhagen Posts: 18 ![]() ![]() ![]() |
I have an issue …
Oil leak at rear wheel, fluid smells like transmission oil. Brake drum dry. Are told that it is the breather that is blocked. But are not told what to do. Can anyone of you please tell me? ![]() Click image to enlarge |
the breather is 9mm tub runs the axa to the engine bay you will clear tub blockage
next you will need sort oil seal and Gasket Leak http://forums.lr4x4.com/index.php?showtopic=32989 http://mud4fun.com/2011/08/06/fitting-new-...e-flanges/ |
Martin Site Admin Member Since: 02 Apr 2007 Location: Hook Norton Posts: 6657 ![]() ![]() ![]() |
Also check the rubber cap for splits or cracks
CE TD5 Member Since: 20 Nov 2014 Location: UK Posts: 51 ![]() ![]() ![]() |
You must be a night owl like me Martin
I was just having one last sweep around the forums
