Home > Technical > 1985 Ninety, leak at rear wheel
Tfaerch
Denmark 1985 Defender 90 200 Tdi SW Rutland Red
I have an issue …
Oil leak at rear wheel, fluid smells like transmission oil.
Brake drum dry.
Are told that it is the breather that is blocked.
But are not told what to do.
Can anyone of you please tell me?
Post #455048 14th Sep 2015 6:20pm
dorsetsmith
the breather is 9mm tub runs the axa to the engine bay you will clear tub blockage
next you will need sort oil seal and Gasket Leak
http://forums.lr4x4.com/index.php?showtopic=32989
http://mud4fun.com/2011/08/06/fitting-new-...e-flanges/
Post #455052 14th Sep 2015 6:36pm
mikeh501
What he said. Reason blocked axle breather causes this is because heat expands the contents of your axle case and the easiest exit is to push past the oil seal behind the stub axle. Easy to fix though. Could also be because the vehicle has stood and your seals are past their best.
Post #455125 14th Sep 2015 9:43pm
Martin
Site Admin
Also check the rubber cap for splits or cracks  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #455135 15th Sep 2015 12:08am
CE TD5
United Kingdom 2005 Defender 90 Td5 HT Cairns Blue
You must be a night owl like me Martin Very Happy
Post #455136 15th Sep 2015 12:14am
Martin
Site Admin
I was just having one last sweep around the forums Wink  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #455172 15th Sep 2015 8:44am
