Home > Wheels & Tyres > 285/75/16 on Sawtooth wheels anyone ?
Crs90
Evening all, is anyone running BFG MT /AT in 285/75/16 size on Sawtooth wheels ?
If so has anyone got any pics ?
Not sure if they would be too large (wide) for that rim,
cheers Chris.
Post #454734 13th Sep 2015 6:03pm
mikeh501
You will find plenty who run 285 on 7j rims but the tyres should really be on 8jj
My fav is 255/85/16
Post #454738 13th Sep 2015 6:29pm
Lambley
United Kingdom 2006 Defender 90 Td5 HT Java Black
These were for sale on here a while back, maybe killer has some pics of them fitted, might be worth a pm....
http://www.defender2.net/forum/topic35067.html?view=previous
Post #454787 13th Sep 2015 8:16pm
need4speed
285/75-16 mickey thompson on sawtooth alloys with 30mm spacers..
Post #455250 15th Sep 2015 2:38pm
Defender-Stu
I have been told 285x75x16 will mess up the gearing and could damage diffs and use more fuel?
Post #455255 15th Sep 2015 3:00pm
TDCi Guy
United Kingdom 1996 Defender 110 300 Tdi HCPU Auto Keswick Green
I run 285/75/16s although on boost alloys, they've been trouble free for 12 months now.
Obviously, like for like, a tyre with more contact with the road is going to use more fuel. However if you go for a more fuel efficient tyre in the 285 size to what you were already running in the previous size then they could actually work out better on fuel.
In my situation I went from the standard grabber TRs to 285 BFG KM2s, I haven't noticed an increase in fuel consumption nor any adverse effects on gearing, the speedo reads the right speed at this size too!
Not sure on how a change in tyre size would cause any damage to your diffs, aside from the fact that having chunky tyres makes you try to drive up things you probably wouldn't with stock tyres on Laughing Tom
@tditomprice
100” Defender Hybrid
2010 Alaska White 90 HT
Post #455261 15th Sep 2015 3:24pm
Defender-Stu
Where is the like button lol, will have a look myself then Thumbs Up
Post #455268 15th Sep 2015 3:56pm
need4speed
Will raise gearing slightly. So acceleration will be dampened a little but at 70mph your revs will be reduced so in actual fact on a steady run your mileage will actually improve.. If your concerned about losing a little acceleration either get a remap or do what I did and fit a 4.6 V8...... Laughing
Damage diffs? Nonsense..
Edit: Tyres don't damage diffs, bad driving does. Some people can grenade diffs with standard tyres/power.. Laughing
Post #455293 15th Sep 2015 5:30pm
Defender-Stu
Ooohhh dont talk V8 to me I get all excited lol Whistle Thumbs Up
Post #455296 15th Sep 2015 5:36pm
Crs90
Cheers for the replies
Chris.
Post #455349 15th Sep 2015 7:47pm
jackp
United Kingdom 2009 Defender 90 Puma 2.4 PU Stornoway Grey
I'm running a set on 16" sawtooths. I love them, kinda wished I had gone whites out tho. Big Cry
Post #458591 28th Sep 2015 6:47am
need4speed
What spacers you using jack?
Post #458611 28th Sep 2015 9:02am
jackp
Sorry forgot to say. There is a 30mm spacer on there, not sure of the make as bought them second hand. Seem strong and reliable so far. Been on about 3 months now. Let me know if you want any other pictures from angles or inside arches etc.
Post #458665 28th Sep 2015 12:23pm
mikeh501
Because your gearing is taller (because the tyres have a bigger radius and thus a bigger circumference) which throws out your speedo a little, and which means you need more right foot to get up to speed using more fuel. The tyres are probably heavier too and effect it because of the extra mass which needs to be get rotated.
The reason for diffs only applies off road and is because all that extra mass spinning on the end of the shaft is easier to cause a failure just simply because the tyres are bigger and heavier. Heavy off road typically involves spinning the wheels either on mud or rocks where your tyre can go from spinning to stopped v.quickly, and in that event that force is transmitted down your transmission. You can apply the same logic to tyres of the same size which have a more aggressive tread pattern. They now dont slip, they bite which transfers that load down through your shafts into your diff and transmission.
Its a slippery slope of upgrades which leads to more upgrades as you beef up one area and then work backwards to other items. Ultimately you end up at the transfer box and gearbox!
Post #458673 28th Sep 2015 12:53pm
wizz80
Was thinking of going that size myself but I don't have any lift will clearance be a problem I have spacers
Post #462887 13th Oct 2015 12:43pm
