Home > Technical > Diff-Lock warning ight switch - LT230 Transfer Box
CFB
Need some help please folks, diff-lock light is stuck on and won't go out (system is not wound up) despite the diff-lock itself disengaging (jacked up to test).
Not sure where the switch is located but am guessing it's the obvious one protruding from the side of the transfer case on the nearside of the car?
Anyone know if this is indeed the switch? I know it's not the reverse lights as that one is higher up the box however if I unplug the connector from this switch the diff-lock light stays illuminated.
Help please! Andy
Post #39944 6th Sep 2010 11:30am
Martin
Site Admin
Didn't know the Japanese were fitting LT230s Wink
Diff lock switch generally has two spade connectors going to it, one wire is black with a blue stripe and the other is black.  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #39963 6th Sep 2010 2:25pm
CFB
Think I have found the DL switch, it's in the top of the case and a Censored to get to Evil or Very Mad
Still have no idea what the switch with the spade connectors in the side of the casing is though Confused
Plenty of Disco's were registered in Japan Martin Whistle Andy
Post #40173 8th Sep 2010 1:49pm
