![]() | Home > Technical > Diff-Lock warning ight switch - LT230 Transfer Box |
CFB Member Since: 13 Sep 2007 Location: Bradford, West Yorkshire Posts: 803 ![]() ![]() |
Need some help please folks, diff-lock light is stuck on and won't go out (system is not wound up) despite the diff-lock itself disengaging (jacked up to test).
Not sure where the switch is located but am guessing it's the obvious one protruding from the side of the transfer case on the nearside of the car? Anyone know if this is indeed the switch? I know it's not the reverse lights as that one is higher up the box however if I unplug the connector from this switch the diff-lock light stays illuminated. Help please! Andy |
Martin Site Admin Member Since: 02 Apr 2007 Location: Hook Norton Posts: 6647 ![]() ![]() ![]() |
Didn't know the Japanese were fitting LT230s
![]() Diff lock switch generally has two spade connectors going to it, one wire is black with a blue stripe and the other is black. ![]() ![]() |
Think I have found the DL switch, it's in the top of the case and a
![]() ![]() Still have no idea what the switch with the spade connectors in the side of the casing is though ![]() Plenty of Disco's were registered in Japan Martin ![]() |
