- You are currently viewing DEFENDER2.NET as a guest - Register to take part or Log In
Home > Td5 > First things to do on a TD5 Defender... |
SailingTom
Hufflepuff wrote:Unfortunately the X-eng pedal box won't fit if you have the air con panel fitted on the Td5 I've seen that pedal box and its absolutely superb - so easy to activate that there is no reason not to use it everytime you get out, but gggrrrr....
It will you just have to adapt it a bit, ive got one on mine with aircon after seeing someone else on here who has aswell.
14th Sep 2015 3:55pm |
