Home > Td5 > Suspension? |
Mr Baldylocks Member Since: 15 Jul 2010 Location: Nearer my home than yours. Posts: 487 |
Evening Guys and Girls, I want to change the springs, shocks & bushes on the old girl but I'm after some advice. Terrafirma or Pro-Comp for the shocks, I want a 2 inch lift but don't do any off road work (sorry) only interested in annoying Boy Racers and car driver and last but not least what would be the best bush kit replacement? Hope to hear your recommendations. Cheers Life is one big adventure, that's why we have the vehicle for the journey.
3rd Sep 2010 7:45pm |
markb110 Member Since: 22 May 2010 Location: Guildford Posts: 2625 |
Go Terrafirma on the shocks as - very well made and help to remove body roll
A friend of mine stapped the head off one pro comp and another leaked within six months of fitting them. On my 90 i was happy with the standard springs so just added Gwyn Lewis 1 inch spacers and dislocation cones as mine gets used on and off road. With the Terrafirmas i also removed the anti role bars without any issues on the road. Good Luck Mark |
3rd Sep 2010 10:27pm |
I had Koni Heavy Tracks under my Camel. They are very good and are adjustable.
I didn't change anything on my 90 yet, but when I change i will go for Koni's again. Roel 1984 90 2.5 na Diesel - RR V8 (1994-2001) 1997 Camel Trophy Discovery 300TDI (2001-2009) 2005 G4 Discovery III 4.4 V8 (2008-2018) It's gone but it still hurts. 2003 90 Td5 (2009-now) |
4th Sep 2010 7:16pm |
landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 5682 |
I have just changed mine from Koni's that failed overnight, to Terrafirma springs and shocks. Very happy with them. I would recomend.
I also fitted Super Pro bushes, and would only use these or original. Andy |
6th Sep 2010 5:54pm |
Cheers Guys, that's made my mind up. What about Britpart bushes? Does anyone have the 2 blanking plates that go on the OE Rubber A-bar? Life is one big adventure, that's why we have the vehicle for the journey.
6th Sep 2010 6:46pm |
Never ever ever ever fit anything with Britpart written on it.
Just my advice Andy |
6th Sep 2010 6:51pm |
Cheers Andy, what bushes would you recommend? Life is one big adventure, that's why we have the vehicle for the journey.
6th Sep 2010 8:52pm |
I would fit Super Pro bushes, they are the best poly bushes.
Or Fit Land Rover bushes, but these require a press to have them fitted, and I don't have one If you want Super Pro bushes, Avenger 4x4 are doing them for £100 inc., when normaly they are £150-170 plus vat. (but limited amount) Andy |
7th Sep 2010 7:06am |
Cheers mate, I'll give them a buzz. Life is one big adventure, that's why we have the vehicle for the journey.
7th Sep 2010 6:47pm |
Cibit Member Since: 26 Oct 2009 Location: Northumberland Posts: 424 |
This seems to be an appropriate place to post this.
I upgraded my shocks and springs to cope with all the extra weight. I went for the terrafirrma TF116 and TF117. The springs where flat dog HD medium weight springs. The problem I have arose through some fairly standard articulation Click image to enlarge but the flatdog springs are shorter than the OE ones. Hence 2 dislocated springs. I only noticed when the smell of burning rubber got in the cab. The springs had been rubbing against the tyres It also turned my rear anti roll barthrough 180 degrees. Solution. pack the anti rollbar mounts with spacers and use jubillee clips to hold the springs to the top mounts This reduces the amount of articulation So the moral of the story is be careful what you do :thumbsup: Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated 59 2.4 110 XS Utility 55 TD5 110 CSW Special Vehicle |
17th Sep 2010 4:16pm |
gav///m5 Member Since: 02 Oct 2010 Location: south staffs Posts: 6 |
I have a 2005 Defender 110 XS and have fitte genuine Landrover anti-roll bars to the front and rear axles which has eliminated more bodyroll although the next mod will be the fitment of 18" wheels in order to get lower profile tyres than the standard Grabber TR's so as to get rid of the tyre side wall flex.
The sum total of my off roading is getting my caravan off the farm where it is stored and then towing onto a pitch |
19th Oct 2010 1:46pm |
