Home > Puma (Tdci) > Brand new 110 XS Puma losses power |
The Boy Member Since: 28 Aug 2008 Location: East Northants Posts: 1459 |
Once when my first Puma broke down it was recovered to hartwells in Nothampton. Normaly I would not go near them but as I had just pulled out of a garage (two miles away) after filling up when it died I had no option. Anyway I got it back two weeks empty and with only about 2 gallons left in it. What a row I had with them, they were so rude and in the end just told me to leave or else. I will never go there again! |
6th Jan 2011 2:17pm |
MK Member Since: 28 Aug 2008 Location: Santiago Posts: 2414 |
So a bad thermostat does not kick the MIL light? Puma 110" SW
6th Jan 2011 2:28pm |
kingofthesparks Member Since: 06 Jan 2011 Location: Very close to Watford gap services , northants Posts: 987 |
Temp gauge did not go into red , only went 3/4 up .
6th Jan 2011 2:50pm |
hcs Member Since: 13 Jan 2011 Location: Cape Town Posts: 3 |
My first post on this site.
My 2008 Puma does exactly the same. Just a sudden loss of power. It can happen from start up, while driving, pulling away etc. No warning lights, no smoking or yerking. Also no rise in temp on the gauge. Only way to get it back to normal, is to stop, switch off and back on. I do notice however that it seems to be worse when its really hot outside. In winter I havent had this problem. Stealers just scratch their heads, can be this, can be that. But no fix yet |
13th Jan 2011 8:15am |
Did he investigate the EGR valve? Puma 110" SW
13th Jan 2011 8:37am |
AFAIK they looked at the EGR, but it seemed to be fine.
And they guy said its still making the "right" noise when shutting down the engine Going in again today perhaps to have them do a diagnostic again. Last time no faults came up, apart from a dirty ABS sensor on the right rear wheel |
13th Jan 2011 8:47am |
have the same and the scanner did not detect anything! I can not drive it for the moment, but after consulting dgardel, it would be a good idea to clean some sensors (MAF, MAPT, fuel pressure, etc). Puma 110" SW
13th Jan 2011 9:02am |
Naks Member Since: 27 Jan 2009 Location: Stellenbosch, ZA Posts: 2638 |
This problem (esp when it's hot) is symptomatic of the presence of a ceramic plate on the turbo inlet hose. On the later model Puma this have been removed, allowing a metal plaque to close/open.
HCS, give Fanie a call at LR N1 City, he will be able to explain it to you in more detail. The last time I was there he looked at my engine bay and told me that mine is the updated version and should not have this issue. |
13th Jan 2011 4:52pm |
ceramic plate on the turbo inlet hose?
can you explain more plesase? Puma 110" SW ............................................................. Earth first. Other planets later |
13th Jan 2011 5:38pm |
this from the technical guy at my stealer:
17th Jan 2011 3:18pm |
